trans. fluid
Old Jun 9, 2007 | 08:02 AM
mj008's Avatar
need help!!!
Default trans. fluid
am i just a complete idiot or is there no dipstick on a 89 s13 to the trans?.
Old Jun 10, 2007 | 08:55 PM
240gun91's Avatar
nope no dipstick.
Old Jun 11, 2007 | 03:27 AM
shinmei2006's Avatar
there is on an auto...lol
http://www.hashiriya.net
Old Jun 11, 2007 | 04:37 AM
norachelhere's Avatar
fails.....
if it is a 5spd, then no, no dip stick, as far as i am aware, there isn't ever a dip stick on any manual car...
if it is an automatic, then yes, there is a dip stick, and as far as i am aware, there will always be a dip stick or an automatic.
Old Jun 11, 2007 | 10:19 PM
harleys's Avatar
what he said.
2008 Ford F150 - Work Truck
1991 XJ - 5.5" lift
Old Jun 12, 2007 | 04:31 AM
Durdan's Avatar
No Ants Drift Member
5speed trannies, much like differentials are filled to a level that denoted by the fill hole. the correct fill hole for the transmission is on the side. when fluid reaches the height of the hole, its full.
but its a bitch. drain out the bottle, fill thru the shifter hole (remove the shifter first). fill with 2.5quarts of gear lube.
RIP Tim. i miss you, buddy
