DO you need a SAFC for a n60 maf on s13 dual
i was wondering if it needed one with a stock ecu, i was just going to wire it and run it stock, some1 plz tell me if there is anything i need to know
whats the point of running a n60 if the car is stock? usualy the maxima and 300zx mafs are ran because of the turbo and the stock mafs max out. and the SAFC is used to pull timing and fuel for tuning. if the car is stock just find a stock maf and use that....up grading is pointless right now and you dont have to wire a stock one in
[/CENTER]
[/CENTER]
Yes you have to use an SAFC for an N60 with stock KA ECU. The N60 mafs will meter approximately 60% more air as well as having a different airflow vs voltage curve.
