ka24de question?
ive got a 240sx and my headgasket is bad and im thinkin of gettin a newer ka from the newer body style
is there any diffrences between tha s14 ka and the s13 ka?
do i need to change the ECU?
i dont want bullshit
repp will be givin!
repp will be givin!
need a car audio or alarm install
Msg me!
Msg me!
most time the diff is single cam and twin cam, the harness is also diff, was the blown up ka twin??? if its twin you shouldnt buy a new motor you should put a new HG on it and boost, anyway i drive an s13 and i love the hell out of it just ask me if you have any questions, i work S&R Performance names jeff
dual cam to dual cam, there aren't really any differences. you'll find that mounts/brackets are different. the intake manifold is a touch different, but everything plugs in just fine. you'll also need to use your s13 dizzy, unless you want to change your harness.
there isn't anything major, is just a bunch of little things. my advice, compare everything side by side. if it is different, find out why and see what you can do to fix it, if you need to.
good luck
good luck
