ac stuck on floor or defrost
Old May 1, 2007 | 05:58 PM
sleeperEK9's Avatar
Getting Dirty
Default ac stuck on floor or defrost
my ac wont let me switch back to the main vents only between the floor and defrost....anyone know how to fix it or what the problem is.
-----SOLD
http://www.myspace.com/whitebreadrs
Old May 2, 2007 | 06:25 PM
sleeperEK9's Avatar
Getting Dirty
anyone????
-----SOLD
Old May 2, 2007 | 06:45 PM
170k240's Avatar
Will Drift For Tires
i had that problem, i jsut switched between setting a bunch of times and it was fixed lol
Nissan North America - Canton
Old May 2, 2007 | 07:17 PM
Ph34r's Avatar
ΔxΔp ≥ h
There is a cable that switches between the settings, perhaps it's stuck or the vent that splits the airflow is stuck. Only way to tell is to pull the dash and have a look underneath. That and keep your intake vents clean to keep debris out of the system.
Old May 2, 2007 | 08:57 PM
norachelhere's Avatar
fails.....
that slider that you use to switch between then, is connected to a cord. its a metal cord that is inside a plastic "shield" the metal cord moves inside the plastic. The plastic gets attached so it doesn't move at all. If that attatchment goes bad, then you'll move the entire cord, not just the internal metal piece and therefore, it won't move the vent.
the only way to fix it is to get behind the dash and all that jazz.
or it could be something completely different..... regardless, you're gonna have to get under the dash and its a pain in the ass....
good luck
Old May 3, 2007 | 09:38 AM
dan's Avatar
dan
Get the fuck off my lawn
s14's HVAC controls are totally electronic.
sounds like one of the motion arms that opens one of the air mix doors is stuck or not responding.
Old May 5, 2007 | 12:23 PM
nisson93's Avatar
deffently the cable that switches is broke or frayed
Old May 5, 2007 | 02:50 PM
Croba_Killa's Avatar
i am not to sure all i know is on my mustang it was a vac line just in case it isn't the cable just trying to help
K.P.A. Crew
