s14 sr20det swap? got fuel but no spark
Old Apr 25, 2007 | 04:09 PM
grn93sleeper's Avatar
s13 newbie
Default s14 sr20det swap? got fuel but no spark
i did a blacktop swap in my friends s14 but im getting no spark,its got fuel and its cranking over just fine but no spark at all.the harness has not been cut or changed in any way and the only thing not plugged in is the MAF sensor.im thinking the ignitor chip or the cam angle sensor is fucked but any other ideas what would cause this?
Old Apr 25, 2007 | 04:55 PM
xnissan240x's Avatar
Fishes more than you
use a test light and check everything that has to do with your ignition system , when you come across somewhere where u dont have power then you found your problem
Old Apr 25, 2007 | 04:59 PM
s13 newbie
dont have a test light but ill do that when i get one...
Old Apr 25, 2007 | 05:30 PM
sameo2's Avatar
infiniti tech
i got the same concern and found out the ignitor was bad.angle sensor only for firing order.
Old Apr 25, 2007 | 06:40 PM
s13 newbie
im stuck at work right now but ill take the ignitor off of my car and try it when i get off work..thanks guys
Old Apr 25, 2007 | 08:49 PM
s13 newbie
ok the chip did'nt fix it...errr this sucks,im getting paid to do this swap cant even make it run..hopefully i get it running so my rep is'nt fucked.
Old Apr 26, 2007 | 03:50 AM
Epstein's Avatar
Retired
Make sure that the coil packs have power. That +12V feed only powers the coil packs so its easy to have everything except spark if it's not connected. If it's in an S14, recheck your connections at F4, dash connector.
Old Apr 26, 2007 | 10:11 AM
s13 newbie
yeah i have'nt had much time to really check it out that good yet.thanks for the input guys.
Old Jun 21, 2008 | 04:13 PM
Joevanni's Avatar
it could be u cam angle sensor
