Clutch Help!!!
Old Apr 16, 2007 | 10:02 AM
chome's Avatar
Will sleep for food.
Default Clutch Help!!!
Today when I was driving my car wouldnt switch gears without any grinding or resistance (every gear) and I don't think its the tranny cuz it just started today. I have my clutch engaged all the way and it will do the same thing. Any info maybe clutch line or tranny fluid? help please
Old Apr 16, 2007 | 04:08 PM
chome's Avatar
Anyone?
Old Apr 16, 2007 | 05:29 PM
170k240's Avatar
Will Drift For Tires
change your fluid. redline mt-90
Nissan North America - Canton
Old Apr 16, 2007 | 06:07 PM
chome's Avatar
thanks im doing it tomorow. will post feedback
Old Apr 16, 2007 | 09:15 PM
Jonas's Avatar
bleed the system properly. look for leaks on the firewall inside the car. check the slave.
are u losing any clutch pedal pressure? or is the pedal feel speratic throughout the drive??
Jonas
Old Apr 17, 2007 | 04:07 AM
Superluminal's Avatar
The Cyber Brain
I have this problem as well. The pedal freeplay keeps changing at different positions while driving. I've changed out master and slave cylinder, and bleed the system accordingly to no avail. I've been told it's a bad pilot bearing issue. Any input?
Old Apr 19, 2007 | 05:54 PM
chome's Avatar
it drives perfectly now for some reason. i did lose some pedal pressure but then it just went back to normal. but for the past few days its been fine.
Old Apr 19, 2007 | 06:14 PM
170k240's Avatar
yeah, i totally forgot to mention checking out the master and slave cylinders for the clutch
Old Apr 20, 2007 | 06:44 AM
kober's Avatar
Don't Drink And Drift
hey, can can some1 write down steps to change tranny fluid? i need to change mine too.. thanks.
oh yea i have a 92 240sx..
Old Apr 20, 2007 | 10:06 AM
170k240's Avatar
1. maake sure you car is on a level surface, of jacked up levely
2. using a half in drive socket recnh, take out you fill plug on the drivers side of the tranny.
3. get you oil pan out and using the same half inch drive wrench, take out the bottom drain plug.
4. remember to wipe any metal shavings off of the magnet.
5. let all of the fluid drain out and screw the plug back in
6. either with a tube, run the fluid into the fill plug hole, or take our your shifter assmbly and fill it through there. (the second one is easier IMO)
7. fill it till it starts spilling from the fill plug.
8. put the fill plug back on.
take it for a spin
