Finally going to Rebuild my KA
I've finally made the dicision to go ahead and attempt my first rebuild engine, starting with my 240sx ka. I'm posting this thread looking for advice from people that have done it and maybe know some of the problems i might face. also looking around for rebuild kit so maybe some of you guys know of some good ones and advice is highly appreciated.
Rebuild with lower compression and forged internals.
Then booooost it!
Then booooost it!
go on AMS.com and check out there rebuild kit. its probably the best one around for the KA. its not a stock rebuild kit, its for forced induction.
and honestly, for me, the KA is very easy to rebuild, you shouldnt have much trouble. except maybe changing out your valve seals.
Nissan North America - Canton
nothing came up under the website?,aslo looking to rebuild my ka for boost
If ANYONE NEEDS ANYTHING TOWED / MOVED IN THE TAMPA AREA PM ME ,ROLLBACK ON THE READY CHEAP!
i've not done a whole lot of head work so i don't have alot of experience with valves and such, however, everything else was rather easy. Craftsman makes swivle 10/12/14mm sockets and they came in handy alot. things like taking the intake manifold off. it was a 5 minute job with that swivel 12.
other than that, find a good shop manual. (well worth the investment) and pay attention to details. The 240 is pretty easy to rebuild, its not like some other imports where you need a 10, 13, 15, and a 16 mm all in 6 inches.
good luck
good luck
the head is very easy to rebuild, but if you dont want to give it a shot then send it to clearawter cylinder head, if u dont feel like buying swivils then just take off the lower bracket that holds the intake many and then take off the bottom part of the mani then the top (ive pulled intake manis off so many times ive got it to a science lol) but motor rebuilding is easy on this one just make sure u do the timing right.... uh just go to a auto parts store for the parts becus usually rebuid kits dont come with everything u know..... sory for the long continuing sentences
on ams you can get a rebuild kit which consists of sportsman series rods, clevite main and rod bearings and a fel pro gasket set for . on IPP you can get
Complete Gasket Set
Copper Head Gasket (to 30 psi)
WISECO Pistons
(89.5, 90, 90.5 & 9-1 comp)
(89.5, 90, 90.5 & 10.5-1 comp)
(89.5 & 8.5-1 comp)
ROSS/Wiseco Stock Bore 89mm
ROSS Performance Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
Expansion Plugs
for $1,070
or you can get
toga main and rod bearings
eagle rods
wiseco pistons
ross performance rings
TOGA Complete Gasket Set
TOGA MLS Head Gasket (for gas & turbo to 30 psi)
TOGA Copper Exhaust Gasket (fits stock exhaust or headers)
TOGA Performance Valve Seals (Teflon)
TOGA Crank Seals
for $1,170
Now you tell me that Aint a fuckin deal compared to AMS. shit they want $400 for a koyo radiator while you can get 1 off ebay for $290 shipped.
Complete Gasket Set
WISECO Pistons(89.5, 90, 90.5 & 9-1 comp)
(89.5 & 8.5-1 comp)
Thrust Washers
Expansion Plugs for $1,070
or you can get
eagle rods
wiseco pistons
TOGA Crank Sealsfor $1,170
