transmission leaking fluid
my transmission is leaking fluid near the release bolt for fluid, not from the bolt because when i look under the car theres bolts that hold it together like theres 2 pices to the tranny and it is dripping between the 2 pices right near the realease bolt. Im not sure if I need to tighten them more to spec or if I should just get a new 1. not too familiar with trannys. also the third gear syncro is fucked up u cannot down shift well at all. I bought the 240 from this guy and he put a rebuilt tranny his freind did or so he says its rebuilt and its not doin to well.
