Over heating only in first ten mins of driving
Old Feb 21, 2007 | 11:52 AM
HondaCRX's Avatar
Vtec what?
Default Over heating only in first ten mins of driving
I start driving my car is get will over heat only after drving it for 5mins, then about a few more mins of drving it will cool down back to normal temp and stays there all the time, no matter how much i beat on it. its only when I start driving the car after its been setting cooling down.
Its a 91 ka24det. it only has the stock radiator from a dohc and i know that's one prob but if that was really the prob it would over heat all the time.
I replaced the water pump, thermostat, checked for leaks and have two fans on, that run at the right temp. The only thing i'm missing is that heater hose that runs from the back of the motor behind the thermostat housing. Now could that be the probelm. I dont see how a little hose like that could cause this but its getting to be a big problem.
any help would be great
thx,
mark
Aim: Hondacrxls
Old Feb 21, 2007 | 02:52 PM
ryanawesome's Avatar
i had a 240 with a leaky waterpump. the coolant would be low and it would overheat until the coolant was warm enough and expanded. maybe your coolant is low and you have a leak elsewhere. just a thought
Old Feb 22, 2007 | 05:27 AM
Chadb240sx's Avatar
WillDrft4Head
My car does that aswell KA24DE within the first couple min of driving my temp gauge will spike at over heated and come back down after a min. It doesn't appear to me that my car overheats. I was informed that it was a bad gauge cluster, maybe thats the same for you??
Old Feb 22, 2007 | 05:41 AM
ph0tek's Avatar
Ni-Ten-Ichi-Ryu
you have air
inside
your shit.
burp it, for 15 minutes. backflush it. fix it.
Buying/Selling on TR is like shaving your ass before going to prison. You know your gonna get fucked, you just try and make it as pleasant as possible.
Old Feb 22, 2007 | 05:47 AM
ANTHONY S's Avatar
Elevate your Game
Originally Posted by ph0tek
you have air
inside
your shit.
+1
had that problem months ago
ka's take a while to burp, at least a good 10 minutes,
you have to wait till ALL the air is out or else ur problem will keep appearing
Old Feb 22, 2007 | 11:41 AM
HondaCRX's Avatar
Vtec what?
nope already did that two times.. same thing, and aslo about a bad gauage cant be i have a aftermarket one aswell. well i took the thermostat back out because the car started to over heat and build was to much pressure and was blowing coolent out of the cap. and now it seams to ride fine. idk its weird.
Aim: Hondacrxls
Old Feb 22, 2007 | 11:43 AM
GlacierFreeze's Avatar
Outta Towner :)
Check the water pump as mentioned before? I had an overheating problem a while back and had the water pump changed and no more leaking coolant.
Angry Video Game Nerd =
Originally Posted by moldyhands
Originally Posted by Strangeholliday
To me " old fashion values and morals " just means hes prejudice and believes a woman's place is in the kitchen, That shes not equal to men, and can't open her own door...
how are those values? that's just physics man. can't argue with physics.
Old Feb 22, 2007 | 12:19 PM
Vcruz's Avatar
It might be ur fans bc the fan clutch r known 2 go bad on 240's that happen 2 mine.....put something in the fan while its running and if it stops then ur fan clutch is bad use a piece of csrd board it should chop it up i changed the fan clutch on my 240 5 different times unless u have a different set up...
Old Feb 22, 2007 | 02:06 PM
HondaCRX's Avatar
Vtec what?
water pump is new just put it on yestday... and i am running electric fans so that's not the prob. it seams like the its leaking from around the cap but not too sure. hard to tell and have not gone out to mess with it.
Aim: Hondacrxls
Old Feb 24, 2007 | 11:05 PM
norachelhere's Avatar
fails.....
it sounds like your thermostat isn't working properly.... check it, and or, get another new one.... you should also check your coolant temp sensor, it could be loose, or going bad and just tweaking out....
