need help rep will be sent for an answer
Old Jan 23, 2007 | 11:42 AM
ekcoupe's Avatar
IS FASTER THAN YOU
Default need help rep will be sent for an answer
i have an s13 with sr20det with a t28 turbo...
my first problem is it is breaken up on high boost ...7-10lbs is fine but 11-13lbs.. it breaks up...like it is not getting enough fuel at high boost...
my main concern is after driving for 15 minutes or more.. then sitting at an idle it starts to blow white smoke and when i rev it really blows out... it only smokes for about 2 minutes and stops..the car runs perfect though ... never overheats or anything..
please i need help before i fuck something up... thanks bobby
Old Jan 23, 2007 | 12:18 PM
storey's Avatar
check your oil dipstick and make sure the oil does not look milky(coolant in oil). usually white smoke is coolant getting into the combustion chamber.
Law of Logical Arguement: anything is possible if you don't know what your talking about.
s14a (future project)
s13 sr(404whp/348tq)
eg6 (my truck)
http://www.cardomain.com/ride/676406
Old Jan 23, 2007 | 12:29 PM
ON3GO's Avatar
External-Radiators.com
what fuel pump you running?
ive seen everything from kinked fuel lines to just worn out pumps cause misfires at higher boost levels.
fuel cut?
thats werid that it only smokes for 2 mins after a 15min drive.
was gonna say valve seals but thats not what it sounds like at all.
Originally Posted by Ronald Mcdonald
Your car is the epitome of all the is cool.
99' Golf more_door Canadian special
70' Bug
77' 280Z
76' 280Z
93' 240sx Sold
79' VW Rabbit "Bunny Luv" SOLD!
05' Scion xB SOLD!
88' VW GTI SOLD!
Only one in town where im blown via a dodge and squirted in a MEGA way....
Official TR SR20 Hater!!
Having more then 2 valves per cylinder is over-rated.
2V heads FTW! and Weight Reduction!
Old Jan 23, 2007 | 01:06 PM
ekcoupe's Avatar
IS FASTER THAN YOU
na dipstick is straight just oil, and its running a walbro 255, i just replaced the sock filter on it, i put fuel injection cleaner in it, and replaced the fuel filter.. i just took it for a drive again and at 11-13 lbs. it is popping and sputtering and blowing black smoke out the exhaust.. its still hauls ass on 13lbs.. but is running like shit...
Old Jan 23, 2007 | 01:12 PM
storey's Avatar
i was thinking valve seals too, but that would be blue smoke while the description of the problem stated white smoke.
eg6 (my truck)
Old Jan 23, 2007 | 01:37 PM
ekcoupe's Avatar
IS FASTER THAN YOU
only thing i can think of is upgrade the injectors from 330cc to 550cc or go and get it tuned... what do ya'll think..??
Old Jan 23, 2007 | 01:51 PM
Projekt's Avatar
No
if it isnt tuned, tune it. also check for vacuum leaks, that could be causing the break up in boost.
Old Jan 23, 2007 | 01:52 PM
bender's Avatar
It's the name of my car..
Check your fuel pressure regulator.
Epstein's little brother.
Car Specs:
White 95 Nissan 240sx SE SR20DET w/ 360whp
Red 2005 Nissan Sentra Spec-V
Human Specs:
Electrical Engineer
Old Jan 23, 2007 | 01:53 PM
Projekt's Avatar
No
Originally Posted by bender
check your fuel pressure regulator.
and if you go that far, might as well double check the injectors.
if one of the nissan gods could chime in what the smoke colors mean.
i cant remember what burns what color.
Old Jan 23, 2007 | 02:08 PM
hideinginfl's Avatar
Is moveing on up
does it over heat at all, do you have to add coolant at all, and cant find a leak. even thou the oil is not white you may still have a blown headgasket.
Rip Kevin "Slo-si" Gonzalez 9-13-06
