my speedo is wrong
Guest
Posts: n/a
it says i'm going faster than i really am...and it gets progessively worse as i accel...its about a 10mph avg over...how do i go about fixing this...
(durdan i'm currently googling this so any other help would be great)
Is it always that off, or is it close at low speeds? I run a 4.36geared rear end with 235/40/17 rear tires on a 9" rim and at a true 60mph, my speedo shows 68. It could be someone has changed the rear end out for a different ratio.
thats not enough to alter the signal. could be a few things off.
sensor could be going out, but its unlikely.
the sensor gear could be wearing off. all the ecu see is a pulse, not rotation or direction. could have a chipped tooth or something.
speedo could be going bad.
i say throw in another cluster from a friends car and recheck. what are you basing your speed off of to know what your real speed is?
RIP Tim. i miss you, buddy
