Question on tie rod ends. S13/S14
Old Nov 15, 2006 | 05:18 PM
JDMbyBlood's Avatar
Default Question on tie rod ends. S13/S14
While picking up a new water pump, I think I'll pick up some tie rod ends (outer) since the boots on mine are shot. My question is, Ive read on a different forum that you can use S14 tie rod ends on a S13. Is this true? (Just want to double check. ) Looking at the pics that were posted, the S14's look larger/stronger. Just wanted to see if any of you switched to the S14 tie rod ends. There is VERY little in price difference if any between the 2 and if the s14 will fit, I'll use them...
Thanks...
Old Nov 15, 2006 | 05:52 PM
RubberBerner's Avatar
Sideways Maffia
you know you can get just the boots right?
NOBAMA!
Old Nov 15, 2006 | 06:22 PM
Epstein's Avatar
Retired
Yes. You can also use Z32 inners as well for even more beef, I think. Check out the S13 suspension section at SPL Parts.
Old Nov 15, 2006 | 07:46 PM
Matt Vassallo's Avatar
lifelong learner
You cannot CANNOT use S14 outer tierod ends to an S13.
You have to convert to S14 Inner tierod ends or Z32 inner tierod ends first.
the S13 inners / outers are a different thread diameter.. Only M12 vs M14 if i remember off the top of my head
rest in peace tim.
Old Nov 22, 2006 | 05:28 PM
CFP_IVAN's Avatar
CFP was...
or just get tein tie rods, and tie rod ends, much stronger and almost the same price as stock ones.
Old Nov 24, 2006 | 06:36 AM
smokeyii's Avatar
Smokedogg
i got the teins on my car, make sure you buy both the inner and outers cause one won't work with the stock counterpart, so both have to be replaced. think i paid like $150 for the set or something.
*edit* for all 4 peices
Old Nov 24, 2006 | 05:24 PM
lifelong learner
no, they will work fine if you have an S14.
rest in peace tim.
Old Apr 12, 2007 | 02:04 PM
JR's Avatar
JR
TR Balla Donor Supreme
Will Z32 inner and outer tie rods and ends fit on the S14? I just received my order for a set today in the mail.
James
Old Apr 12, 2007 | 04:51 PM
norachelhere's Avatar
fails.....
for the price you might as well, its alot like when your fuel pump dies, you can spend 140 on a stock one, or 100 on a walboro.... its not quite that nice with the tie rods, but you get the point.
Old Apr 13, 2007 | 08:23 AM
JR's Avatar
JR
James
Could someone let me know if I can use this setup on a S14 (refer to previous reply). Thanks.
James
