sr20det clutch not working???or somthing
Old Oct 8, 2006 | 08:51 AM
91180sr's Avatar
Default sr20det clutch not working???or somthing
Ok so i was driving last night and on the way out i noticed my clutch felt more loose then normal, then I went to leave gandy and it kept stick to the floor by the time i got home i was stoping and starting the car in gear to park. ANYONE??
Old Oct 8, 2006 | 12:45 PM
Matt Vassallo's Avatar
lifelong learner
it sounds like your slave cylinder gave up on you.
rest in peace tim.
Old Oct 8, 2006 | 12:57 PM
SpottedMango's Avatar
Driven Concepts, Tampa FL
Didn't you just get a new slave?
Like MV said, sounds like a slave.
Driven Concepts, LLC
1101A East Hillsborough Ave.
Tampa, Florida 33604
813-236-4500
Monday - Friday 9am - 6pm
WE ARE DIRECT
Tein, GReddy, Buddy Club, Bride, Tanabe, K-Sport, Power Enterprise, etc......
https://www.tamparacing.com/forums/d...ml#post4905630
Old Oct 8, 2006 | 01:36 PM
lifelong learner
If he just replaced the slave, chances are inexperienced-mechanic'itis improperly adjusted the pedal, causing premature hydraulic system failure.
rest in peace tim.
Old Oct 8, 2006 | 01:58 PM
Alex, which did you get changed out? The slave or the master?
813-236-4500
WE ARE DIRECT
Old Oct 8, 2006 | 03:24 PM
91180sr's Avatar
I got the slave replaced with the new clutch. Is it hard to change out the slave ? Cause i was gonna do it and bring it up to u guys to adjust it this weekend. Is that cool?
Old Oct 9, 2006 | 04:44 AM
ph0tek's Avatar
Ni-Ten-Ichi-Ryu
If your replace any part of the clutch system, you should replace all the parts, the master is like 20 bux, check and make sure fluid is not coming into the inside of the fire wall, (bad master and will cause this) and also check the slave, make sure the slave is fully engaging when pedal is depressed.
Make sure the system is fully bled, (dampner is removed).
Next step.
Clutch.
Buying/Selling on TR is like shaving your ass before going to prison. You know your gonna get fucked, you just try and make it as pleasant as possible.
Old Oct 10, 2006 | 06:57 PM
blackGS's Avatar
if the slave has been replaced the master is probably what wrong,check for brake fluid leaking on to your carpet above the clutch pedal
Old Oct 11, 2006 | 11:18 AM
Shadytrixta1's Avatar
has whippled VTEC
Get rid of the damper box.That did the trick for mine.
