Squeaking Steering Sound...WTH
Old Oct 2, 2006 | 04:30 AM
ImportLuv's Avatar
Default Squeaking Steering Sound...WTH
Makes a squeaking sound when i make turns to the left, but not the right.
Just a simple small turn to the left makes that squeak. it's annoying.
S14
Old Oct 2, 2006 | 05:52 AM
Anthony R's Avatar
SAL-T
+1 on my s13. idk what it is.
Matthew "RudeBoy" Nugent 2/03/88-04/01/09
Old Oct 2, 2006 | 05:55 AM
ImportLuv's Avatar
It's not the sound when you run out of steering fluid, it's just a simple squeak like opening a gate or something with hinges. Metal to metal rubbing.
I have suspicion (sp?) that it might be the rack & pinion, but not sure.
Old Oct 2, 2006 | 06:51 AM
Anthony R's Avatar
SAL-T
i loooked at mine today and i noticed my spring is bent and it is not even on the top pf the shock. wtf. so that might be my problem?/
Old Oct 2, 2006 | 07:27 AM
Jubee's Avatar
Baby Rhino
wow thats really weird i am having the same prob been trying to figure out what it was.
Old Oct 2, 2006 | 07:43 AM
ph0tek's Avatar
Ni-Ten-Ichi-Ryu
Check and make sure the srpings are seated right in the cups.
Check bushings and wet/dryness of the boots on the rack.
in other words. Get under your car and check shit out.
Get off the fuggin internet.
Buying/Selling on TR is like shaving your ass before going to prison. You know your gonna get fucked, you just try and make it as pleasant as possible.
Old Oct 2, 2006 | 07:57 AM
ImportLuv's Avatar
No time to take it to the shop. work and school...work and school
posting this only takes a few minutes. driving to a shop, explain to them, and drive back takes a hour.
Pretty much every 240 that i see, has a broken tie rod boot. maybe that might be the cause? driving for years with no grease on the bearings.
Old Oct 2, 2006 | 07:54 PM
ImportLuv's Avatar
I lifted up my car, checked out the coilover, everything is fine and thight.
I think the rack is going bad. Driving around for almost 2 years with broken tie rod boots was sure a bad thing.
Old Oct 3, 2006 | 11:07 AM
92GST's Avatar
my right side is doing it too. mine did it and then i got brandnew kyb struts and lowering springs and it still duz it
