Sr20 Prices
this is just a random /boredom question but are sr's ever gonna go down in value soon or are there any other cheap but reliable places to get them from cus im gonna be doing a kat most likely but i know it wount last forever so i wanna get a sr at the same time but i have a good job with good bos but sometimes theres no work or i am not in the mood to work so i dont make n=much money to invest in things like this ive only been able to fix leaks and such i mean i dont even have coilovers yet
buy the necessities, if your going to build a KA do it right...a properly built motor is as good as any factory block and then some..
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
well what i was going to do with the kat was build a ka but with stock internals just new bearings seals rings exc. and just clean everything else and run 10 pounds on a a/r.60 would that be reliable cus i drift every once and a while
logically if supplies decrease over time prices will increase. So no, i very much doubt prices will go down. just shop around you can usually find a good deal on an sr.
yeah, becareful what is out there.
Good looking prostitutes aren't cheap.
but this is a motor, it can look good outside, but once you put it in the car, it you can only keep your fingers crossed.
