Broke a lug off, need help!
Old Jul 14, 2006 | 07:13 PM
CadetLD's Avatar
Default Broke a lug off, need help!
Okay, I just got my new Enkeis yesterday. As I was takeing my old Rotas off, I noticed one of the lug nuts on my rear passenger wheel was wicked hard to take off. Well I finaly got it off, but with half of the lug still in the lug-nut. How do I go about replacing that lug? Is this an easy job? What will I need to do this?
I've never done this before and figured I'd ask before ripping it all appart.
Thanks, any help is much apreciated. I'll be on AIM later if you want to talk on that instead.
Old Jul 14, 2006 | 07:16 PM
Anthony R's Avatar
SAL-T
should be able to just swap a lug out. not hard.
Matthew "RudeBoy" Nugent 2/03/88-04/01/09
Old Jul 14, 2006 | 08:23 PM
-campy-'s Avatar
buy a whole new spindle
Old Jul 14, 2006 | 09:27 PM
-campy-'s Avatar
he is right i was jus bustin ur balls that is the correct way to do it
Old Jul 14, 2006 | 11:10 PM
lordofthemiasma's Avatar
RIP DJ YOU WILL BE MISSED
its ez as hell. i ddi it to 2 of mine.. i didnt get to break them in the first place tho .. buit it is ez.. jus put washers on them and pull the new ones through
RIP my very best friend. DJ aka djzstang1 you will be missed dearly. I love you bro.
1995 240sx se
1992 240sx
1990 240sx se
1991 240sx hicas sr20det MDX
1991 240sx project coupe
1990 240sx drift beater hatch
1993 240sx sr20det
Old Jul 15, 2006 | 04:08 AM
ImportLuv's Avatar
What does he means by lug? The stud (bolt) of it?
I guess he broke a wheel stud. If so, just replace it. Oh, Epstein, there's no need to remove the brake calipers from the rotors. I replaced mines w/o removing them from the rotors. Just disconnect the brake line bracket on the strut, then simply slide out the rotor with the calipers still on, and move it away. Hammer out the stud, it will pop out. Then slip the new one in, use 5 washers and a lug nut to pull the new wheel stud into place. Then put rotors and wheels back on.
Old Jul 15, 2006 | 05:01 AM
Torrential's Avatar
Built to guilt
Easy as hammering the studs outta the hub and putting in a new one not too hard I broke one or two back when I had my s13 if its just a stud which is what it sounds like go to nissan and pic up a stud and knock the old one out with a hammer it will pop out on the 89 if im not mistaken and you will just need to put a new one in through the back in the hub. Just push the new one till it clicks in and you should be fine.
