help with window
help with window
my driver side window is all f@#% up and i can't seem to
fix it.
- doesn't go up
- sometimes it doesn't go down
- leaks water at the top
- and the motor still runs when the
window does go down.
fix it.
- doesn't go up
Sounds like an errant electrical connection....or
maybe the window frame has a bolt working loose.
Have you pulled the door panel and looked, yet?
If you need help, I have a test light to check for current
to and from the window motor and from other places.-Bob
fix it.
- doesn't go up
fix it.
- doesn't go up
