HELP ASAP...fuel over load problem
Old Jun 10, 2006 | 09:56 AM
black240se's Avatar
KA_T under construction
Exclamation PLEASE HELP ASAP...fuel over load problem
heres the prob..93 240....i installed new injectors..did tune up.....cap rotor wires plugs..and my car wont start do to fuel over load in cylinders,,then it just soaks the plugs....timing is dead on everthing reconnected properly....
could it be fuel pressure reg?
need help asap.....need car running
replaced regulator no effect CAR RUNS LIKE HAS NO SPARK BUT HAS SPARK
IREMOVE PLUGS AND THEY ARE GAS FOULED
Old Jun 10, 2006 | 04:37 PM
dsmtuner's Avatar
gotta love the boost
i had that prob it might be a fpr or the vacuum line on the fpr usually the line gets hard and cracks which will cause the fpr to basiclly stop workin.. crimp one of the fuel lines and see if it will start.it should stay runnin after it starts.
SVT F150
Old Jun 10, 2006 | 10:40 PM
tak's Avatar
tak
A to the K
pull the fuel pump fuse and try to start, just to be sure.
Getting no spark, and fouled plugs does not mean excessive fuel, could just be the distributor not firing correctly.
Old Jun 11, 2006 | 10:09 AM
black240se's Avatar
found out injectors werent seated properly dumping fuel instead of in jecting them...car runs now at high idle but surges revs go up and down....vaccum leak?
