AC Fan?
Old May 5, 2006 | 11:52 AM
Projekt's Avatar
No
Default AC Fan?
does the ac fan have to be on the car?
right now mine is not mounted on the bottom the zipties keep breaking. i have never seen the fan run and i dont use my ac ever since it needs a recharge
Old May 5, 2006 | 01:01 PM
Epstein's Avatar
Retired
On the dual cam cars, the "AC fan" actually only turns on if the ECU see that the coolant temp gets too hot. If you have a mech fan and shroud, you're probably fine. But, with the coming summer months, I'd really try to get it fixed.
Old May 5, 2006 | 02:34 PM
Projekt's Avatar
No
its all good i just got down there with a couple of zipties and resecured...then i added more zipties just in case
and i redid my zipties hiolding my lines going across the intake because i dont have a shroud
Old May 8, 2006 | 10:24 AM
ph0tek's Avatar
Ni-Ten-Ichi-Ryu
zipties, I have a shroud in my garage if you want it.....
Buying/Selling on TR is like shaving your ass before going to prison. You know your gonna get fucked, you just try and make it as pleasant as possible.
