CA18det 6psi wt28 want more boost
Old Mar 30, 2006 | 10:18 PM
CadetLD's Avatar
Default CA18det 6psi wt28 want more boost
I have a Turbo CA-DET 240 with a s15 t28 and is only running 6psi, but the t25 that came with it ran 10psi, im jsut curious what i should do to get more boost, and how much i shoud run. it got the stock fuel system, view my garage for specs if i need to. any info will be helpful. thanks.
Old Mar 30, 2006 | 10:25 PM
CadetLD's Avatar
BTW i think the bov is leaking, it makes a leaking noise after about 3psi nad wount pop off untill like 4500rpms, when i had the t25 on it it was loud, didnt make that leaking noise, and sounded every time i shifted above 2500rpms, now all i get is compressor surge noises, need advice for that too. THANKS!
Old Mar 31, 2006 | 05:06 AM
SilentKrnSoulJah's Avatar
(> '.')> V.I.P <('.' <)
off topic but what kind FMIC do you have for your CA18det? and where do you get them ?
thanks
Old Mar 31, 2006 | 06:03 AM
Anthony R's Avatar
SAL-T
check to gaskets on the turbo flanges. that might be the leak our hearing.
more boost. get a boost cotroller and bump it up. i would not run anymore than 11.
Matthew "RudeBoy" Nugent 2/03/88-04/01/09
Old Mar 31, 2006 | 09:08 AM
S13NewB's Avatar
Vice President
Originally Posted by CadetLD
3" straight exhaust leading to an OBX something fartcan....ummm a couple horsepowers worth of stickers
Funny stuff... +1 on the manual boost controller. pretty cheap of ebay, and allow for more boost than the bar rating on your wastegate spring.
Old Mar 31, 2006 | 11:03 AM
CadetLD's Avatar
Im Not sure what brand of FMIC that is, when i was polishing it there were no markings on it. where is the turbo flange? the leak sonds like its leaking thru the trumpet part of the bov, almost all of the parts that are on it, came with it. the stock t25 was leaking oil into the intake, so i got the t28 from Ivan and shawn rewelded the down pipe at CFP.
Old Mar 31, 2006 | 12:24 PM
B16aTeggy's Avatar
My Balls Hurt
holy batman.. might wanna go read up on ur car
bikes
-73 kawasaki z1 900/ 05 cbr600rr motor
-06 675 117whp 52fttq
AIM- B16aTeggy
Old Mar 31, 2006 | 12:30 PM
truffle_shuffle!'s Avatar
Chomsky with dick jokes!
I would worry about the boost leak you have before making any more boost.. the cheap way to go is a granger valve.. The best way is get a cheap electronic boost controler.
There are points in life where one looks at his or her situation and says "how the fook did i get here?" ... this is one of those instances....
Old Mar 31, 2006 | 07:40 PM
CadetLD's Avatar
Granger, isnt that place right near sunshine speedway? and before i plan on doing anything boost-wise i need to get new hardpipes, the guy who had it before me, just hacked up some 2" electical conduit to conect everything together. once again ghetto i know. ill be osting some pics of the engine bay in my TRgarage soon.
Old Mar 31, 2006 | 08:01 PM
CadetLD's Avatar
theres some more pics of my car and engine bay in my garage now, check em out tell me what you think. thanks
