My Timing chain issues.
Old Feb 27, 2006 | 02:45 PM
Igor's Avatar
SR20 power!
Default My Timing chain issues.
Well, about 5 months ago i start to hear a tick coming from the valve cover, after asking some questions and doing a bit of research I was happy to know that it is a common problem with a simple solution: Remove the upper guide. I removed the valve cover to find the upper guide already removed.
It seems that the timing chain is rubbing against one of the lower side guides,
How bad of an issue is this? anything i can do about it? the sound is pretty damn loud sometimes.
edit: Ka24de to clear up any confusion
Thanks.
Old Feb 27, 2006 | 03:35 PM
LongFellow's Avatar
Please hold...
You might just need to replace both of the chains.
Do you know if they have been changed at all?
it could also be a bad tensioner. only way i know to check is to take both upper and lower covers off and check the slack in the chains and see how the tensioners are doing.
hope that helps
Team White Car 2010
Old Feb 27, 2006 | 04:29 PM
gritt's Avatar
Fuckelberry Hound
you might be able to tell the condition of the lower chain without removing the lower cover. like if it`s stuck alll the way in, you`ll be able to see the chain slack. if it is you`ll need to check the left lower chain guide for it might be cracked from all the slapage.
fyi, the rod knocking on a car i recently purchased was mis-diagnosed as a broken upper chain guide...
SHIFT_old school
399.5 hp 430 tq on 95k mile junkyard motor
12.0 @ 118.22 1.89 60`
DILLIGAF?
Old Feb 28, 2006 | 10:34 AM
Igor's Avatar
SR20 power!
When I first heard the same sound on my miata, i assumed the same thing lol.
Thanks for the help, im going to take a look at it when the car is back togehter.
Old Feb 28, 2006 | 05:08 PM
Xavier240's Avatar
Purple People Eater
im hearing the ticking also. in my 95. if the tensioner is bad is it easy to replace?
Old Feb 28, 2006 | 05:31 PM
gritt's Avatar
Fuckelberry Hound
gotta pull the oil pan to get the lower front cover off. not hard, just takes a while
SHIFT_old school
DILLIGAF?
Old Mar 2, 2006 | 06:40 PM
Xavier240's Avatar
Purple People Eater
im just goin to get the timing chain overhaul thing. btw any1 got a haynes or chilton for sale cheaaper than $20?
Xavier240's Avatar
Purple People Eater
oh yea thanx for info gritt
Old Mar 22, 2006 | 08:37 AM
HONDAMAN107's Avatar
hey yo i have the KA24DE and when i puch on the gas it hames a ticking sound is it bad what should i do i have had all hondas now i have a 240 and all new game from there thanks
