s13 prob
Old Jan 28, 2006 | 07:51 PM
dsmtuner's Avatar
gotta love the boost
Default s13 prob
i need to know if there is anyway to self diag a s13 ecu.i really cant find the chiltons manual for the car.
thanks
joe
SVT F150
Old Jan 29, 2006 | 03:47 AM
tak's Avatar
tak
A to the K
yes
pull the passenger kick panel off, unbolt the ecu from the car, leave the wiring harness connected.
if its a 89-90, turn the screw all the way clockwise, wait for it to blink 3 times, then turn it back counterclockwise....
This will initiate a set of blinks...
if its DOHC 91+ then turn it clockwise, hold for a few seconds, then turn back counterclockwise. This will also initiate a set of blinks....
All this must be done with key in on possition but car off aswell....
Then start counting blinks, on 89-91 red = first digit, green = second digit.
on 91+, you will have a slow flash meaning the first digit (or 10 first 2 digits for 100+ numbers) then sequential faster flashes indicating the second digit of the number, and then a pause, and the next number will come about.
Example is
Blink.........blink........Blink.........blink.... ....Blink
then
blink...blink....blink...blink....blink
then
.....long pause......
next number.
heres a partial list off 240sx.org of codes/meanings. I think most nissans share the same codes, so if its not on there, post it and we can find it
11 - Camshaft Position Sensor
12 - Mass Air Flow Sensor
13 - Coolant Temperature Sensor
14 - Vehicle Speed Sensor
21 - Ignition Signal Primary
25 - IACV-AAC Valve
31 - ECM
32 - EGR System
33 - Front O2 Sensor
34 - Knock Sensor
35 - EGR Temp Sensor
36 - EGRC-BPT Valve
37 - Closed Loop
41 - Intake Air Temp Sensor
43 - Throttle Position Sensor
55 - Everything is OK
65 - CYL 4 Misfire
66 - CYL 3 Misfire
67 - CYL 2 Misfire
68 - CYL 1 Misfire
71 - Random Misfire
72 - TW Catylist System
76 - Fuel Injection System
77 - Rear O2 Sensor
82 - Crank Position Sensor (OBD)
84 - A/T Diag Comm Line
95 - Crank P/S (OBD) Cog
98 - Coolant Temperature Sensor
103 - Park/Neutral Position Switch
105 - EGRC Solenoid/V
Old Jan 29, 2006 | 06:23 AM
dsmtuner's Avatar
thank you
SVT F150
