Tire Questions
Tire Questions
If I had Rims with these specs which Size tire would you go with front and rear. They are Staggered wheels so keep that in mind. I found the wheels im getting and need some tire advice i dont want rubber band tires !!!
Size: (2) 17X7.0 20.0 lbs ea +/- 0.5 lbs
Size: (2) 17X9.0 21.2 lbs ea +/- 0.5 lbs
Bolt Pattern: 5 X 100 and 5 X 114.3 (4.5")
Offset: +38mm
or Im gonna go with these !! I cant decide between 17 or 18's
- Finish: GOLD with Machine Lip
- Size: 2 Front Rims are 18X7.5 about 1 2/3" Lip. 26.2 lbs ea. +38 offset
- Size: 2 Rear Rims are 18X9.5 about 3" Lip. 28.0 lbs ea. +35 offset
- Bolt pattern: 18X7.5 are 5X100 and 5X4.5
- Bolt Pattern: 18X9.5 are 5X4.5 (114.3) and 5X4.75
I currently have Front 17x8 +25 with 225/45/17 and Rear 17x9 +35 with 255/40/17
Future plans include stepping up to a 9" front and 10" rear rim for a little more traction. I am still debating between 17" and 18" wheels.
well these are really gonna be for looks not function.. i want a deep dish and staggered, it just looks hella better and mean ! I have Stock wheels for drifting and I have a pair of wheels for dragging, i kinda want the 18's with that fat ass lip. But iunno what size tire to run so it looks right.
These are the 18's
These are the 18's
It doesn't matter what tire size you put on the front, it's going to look like ass with a +38 offset. Go put your stock 16" SE wheels back on for a sec.... the first set will be 8mm farther out, and the second set will be 14mm farther out. The rears will be about right.
If you go with Lincoln's setup on the first set of wheels, they sidewalls will be pretty square. Subtract 10mm of width from each to get a sportier look.
As for the 18's... dude, 28lbs per wheel?! I've seen boat anchors that weigh less. If you just want them for looks, though, it shouldn't matter. For tires just go with the same widths as above and decrease the aspect ratio by 5%.
I dont get what you mean, they seem to fit that red 240 ?
so should i go with 8.5 front and 9.5 rear ?
- inish: GOLD with Machine Lip
- Size: 2 Front Rims are 18X8.5 about 2" Lip and 28.8 lbs each
- Size: 2 Rear Rims are 18X9.5 about 3" Lip and 28.0 lbs each
- Bolt Pattern: 5X4.5 (114.3) and 5X4.75
- Offset: +35mm
