ka running rich
Old Dec 27, 2005 | 11:11 AM
spoonfed's Avatar
Tha numba one stunna
Default ka running rich
has a new o2 sensor and coolant temp sensor. car runs fine but its fouling out plugs and thining the oil to the point where if I put 40 weight oil in it 3 days later its so thin that the lifters are ticking. And needless to say it gets shitty gas mileage.
Where should I start my troubleshooting? Im not sure where to look for the problem. Oh and the check engine light is not on.
... content in sig not work friendly
Old Dec 27, 2005 | 11:26 AM
ANGRYWHITEBOY's Avatar
is it loosing oil or just thinning oil -- how many miles on engine-- is it running hot-possible blown headgasket-- need more info
Old Dec 27, 2005 | 11:53 AM
Rey's Avatar
Rey
is your check engine light on?
Old Dec 27, 2005 | 02:17 PM
RubberBerner's Avatar
Sideways Maffia
massive blow by? are you burning oil too? that causes HC's/ rich condition too. check for leaky injectors. Are your plugs in the right heat range?
NOBAMA!
Old Dec 27, 2005 | 02:39 PM
Shadytrixta1's Avatar
has whippled VTEC
i had an injector stuck open.ran like ass low rpm's screamed in the higher rpm's
Old Dec 27, 2005 | 02:57 PM
spoonfed's Avatar
loosing and thining
probably around 90,000 or so the engine is a 96
does'nt run hot at all runs at around 130-160 Im putting a thermostat in it to get it to run at operating temp faster. but it ran rich before I took the thermostat out.
spoonfed's Avatar
read my first post again
Old Dec 27, 2005 | 02:59 PM
spoonfed's Avatar
yeah it burns oil pretty bad but I think the blow by is from the rings getting washed with fuel. I ran some 2 cycle in it and it helped some but I need to find the actual source of the problem
Old Dec 27, 2005 | 04:20 PM
Epstein's Avatar
Retired
I think Shadytrickstah111 is right. Sounds exactly like a stuck injector. If it was something that effected all cylinders like a vacuum leak, sensor, or FPR, the car would run like ass. A stuck injector would only effect that cylinder. Couple that with the huge ammount of fuel needed to thin oil (daaang!!), and the only thing I can think of that fits the bill is a stuck injector.
Old Dec 27, 2005 | 04:56 PM
spoonfed's Avatar
I'll check them.
