A couple of questions about a disco potato
Old Nov 27, 2005 | 07:04 PM
Derka's Avatar
TR Balla Donor Supreme
Default A couple of questions about a disco potato
Hey hows it going. I have a 96 civic running a custom turbo setup with a stock nissan turbo from a rb25. I want to upgrade the turbo, and i was looking at the gt28rs, since it would be a dirrect "bolt on" swap on my setup, since i am running the same 5 bolt flange on my downpipe as a sr20 or rb25. But my question was, how much bigger is the compressor housing. I had to shave a good deal of my block to fit this turbo on that i have now, and i dont think i could shave it more. Is the gt28rs compressor housing physicly larger?
Thanks alot,
Derek
1998 crv daily beater
Old Nov 27, 2005 | 07:06 PM
Derka's Avatar
Here is a picture of how the turbo im running now fits.
Attached Thumbnails A couple of questions about a disco potato-dsc00028.jpg   A couple of questions about a disco potato-dsc00029.jpg
Old Nov 27, 2005 | 07:50 PM
GsEclipse02's Avatar
Thanks alot,
Derek
i thought they were going to fix that problem ?
Old Nov 27, 2005 | 08:03 PM
Derka's Avatar
It should be fixed, but if this turbos much larger it still wont clear. there is only so much room between the block and radiator
Old Nov 27, 2005 | 08:18 PM
EludeR's Avatar
On the left is a GT28RS (disco potato , keep in mind this turbocharger has a internal wastegate (actuator) ) on the right is a stock s13 sr20det t25 turbocharger. Both are pretty much the same size. I believe the RB25 turbo is a T3 flanged turbocharger , so to get a true bolt in replacement/upgrade for your setup i'd go with a GT28RS t3 flanged turbine , but you would end up having to go with a external wastegate (something i'am sure CMS can do for you). But either way you shouldn't have clearence issues.
Edit: By the way these pictures are from sportcompactcar's website, courtesy of their project silvia.
Last edited by EludeR; Nov 27, 2005 at 08:19 PM. Reason: Forgot to supply source of pictures
Old Nov 28, 2005 | 06:49 AM
Derka's Avatar
external wastegate isnt a problem. thanks alot for your help.. rep points for you
Old Nov 28, 2005 | 08:24 AM
EludeR's Avatar
No problem , and thanks.
Originally Posted by John
i thought RB25's used a T3 turbo???
atpturbo(www.atpturbo.com) sells disco potato's with a T3 flanged turbine inlet, but he would have to cut/weld on a external wastegate flange , so he can make use of it. Since it does not have a internal wastegate like the RB25 T3.
Old Nov 28, 2005 | 05:04 PM
EludeR's Avatar
I'm sorry, I skipped over that part.
No problem.
