o2 sensor wire
Old Nov 26, 2005 | 04:14 PM
tak's Avatar
tak
A to the K
Default o2 sensor wire
i burned mine, and its cut off about 4 inches up.
I cut one off a car at the parts yard, but the wire consists of 1 multithread covered wire, and that is wrapped with wire, then another plastic coating goes around that.
Can I just peel the outer layer off both sides, and take that wire wrapped around, and twist it together, and solder/heat shrink tube it, and then do the same to the inner wire? Or should I use butt connectors?
I need to get this thing replaced, but dont wanna fuck anything up, and from what I remember people saying in the past, these wires are not good to mess with. Just wanna do it right. Any suggestions?
