S14 Master Cylinder
Old Nov 21, 2005 | 04:44 PM
ZenkiS14_Drifter's Avatar
Wombat S14
Default S14 Master Cylinder
So my left rear caliper sticks, right rear gets hot. Ive figured out that the lines are pressurizing and the fluid is not goin back into the resavoir when i let off the brake pedal. Ive tried adjusting the rod in the Booster. onyl other thing I can think of is that valve ( if it is one) in between the master cylinder and the brake line that runs to the rears. Does anybody knwo what this is or anyting about it? Also why is there no proportioning valve on the S14's?
Old Nov 22, 2005 | 06:12 AM
Epstein's Avatar
Retired
The proportioning valve is built into the master cylinder. If there truely wasn't a prop valve, then how could it have a split point at 20 kg/cm2 and a reducing ratio of 0.4?
If your rears are dragging, it means one of several things... or maybe a combination.
-your rear caliper has seized. I really haven't seen this before, even on rears with 230k+ on them.
-your rears need to be bled. Possible, but you'd probably be leaking brake fluid, which would be noticable.
-ebrake is too tight. Look at the rear assembly and find the ebrake cable end. There's a rotary spring holding the arm back. Make sure that arm is all the way back against it's stopper.
-Sliding bars are stuck. I took mine apart and they were super nasty. Definitely doesn't help. Simply disassemble, clean, and regrease.
-The pad clips need to be greased. This fixed my persistent pad dragging problems. Just liberally apply grease to the clips.
So, to cover all the bases, get the car in the air and get the tires off. Unbolt the caliper and regrease the sliding pins. Pop the pads out and grease the clips and ears thoroughly. Reassemble and bleed. Check the ebrake cable where it attaches to the caliper. The good part is, you can put the car in neutral while it's in the air, and spin the brakes while listening for dragging.
Or if you're made of money or you don't want to fix it again for the next 100k miles, just buy 2 new rear calipers. You'll still have to bleed the lines, grease the pins and clips, and inspect the ebrake.
Old Nov 22, 2005 | 09:15 AM
Wombat S14
thanx man...been there done all that...lol do u knwo what that little vale thing is that rear line bolts to on the master cylinder. I have replaced my master cylinder too, but i had to use that valve thing off of mine.
