Ka overheating!!
Old Nov 19, 2005 | 10:28 AM
spoonfed's Avatar
Tha numba one stunna
ok so i got up early this morning and drove the car around with the heat on full til it reached 230 deg. I pulled into a gas station and removed the bleeder screw instanly steam if shooting out this continued for about 20 mins and then it slowed down some so i removed the radiator cap toped it off and it started to bubble some I let it do this for another ten mins or so and kept toping it off then i took the hose from the service area of the gas station and put it in the filler opening of the radiator and flushed it real good and water was coming out of the bleeder screw opening like a fountain I then reved the engine for a while to make sure it was circulating well I replaced the cap and nothing but pure water was coing out of the hole no bubbles I replaced the screw total time of this was prolly around 30-40 mins but Im now confident that there is no air in the system the car was running right under 190 where it should be.
On the drive home Im keeping an eye on the temp and its doing great and running cool all of a sudden the car shuts off. As if someone turned the key off. so I roll it off the road pop the hood. Im instantly thinking it has to be spark since it just shut off instanly no sputter or anything so i remove the connecter that goes to the distributer. Its full of water I guess I got a little messy with my flushing earlier. well i have to be to wrk so i dry the connector and the dist. I take the cap off and not water is inside I make sure the coil and all other connections under the hood are dry and they are. yet everytime I try to restart the car its the same thing...no spark. so I walk home call a tow truck to get the car and leave for work...hopefully it will be dried out by the time I get home. And hopefully i did'nt fy the dist that would suck.
sorry for the novel: cliff notes - got the air out of the system but got my dist connection wet. car shut down on the drive home waiting for it to dry.
... content in sig not work friendly
Old Nov 19, 2005 | 03:02 PM
G-reg's Avatar
hope ur cars working, but I thought it was normal for the needle to be halfway on the temp. cluster??
Tuning
Old Nov 19, 2005 | 05:05 PM
spoonfed's Avatar
I hope it is because I just drove it around the block and its back to running at 260 with the needle halfway up the temp gauge then as Im pulling in the driveway its starts to sputter and idle up and down real bad and stalls and would'nt restart...I'll let it get some sleep and try it again in the morning. maybe there is still some moisture in the connections.
Old Nov 19, 2005 | 06:26 PM
I'm Phucked's Avatar
army pilot
wait that is really hot. Is there white smoke and coolant smell everywhere when you come to a stop? overflow tank full? maybe the good ol' stocker gauge is giving the accurate reading.
The sputter idle up and down really bad happened to me when I lost a vacumn line, brake booster line along firewall is usually the culprit.
In a relationship you are either man or woman choose wisely [fortune cookie @ Ling's garden]
Originally Posted by Tackleberry
thats an insult to a circus
Old Nov 20, 2005 | 09:59 AM
G-reg's Avatar
so if my needle is half way after driving around, then im having cooling problems?
Tuning
Old Nov 20, 2005 | 11:11 AM
extremetrouble's Avatar
dude jach the car up in the fron as high as possible and all the airbubbles will come out had the same problem
Old Nov 20, 2005 | 02:21 PM
  #17 (permalink)
spoonfed's Avatar
I took the car to cfp and shawn flushed and bled the system thoroughly. its idled fine for like 20 mins without getting hot but as soon as I tried to drive it home the temp shot right back up! I think its the headgasket. Im just going to buy a new motor.
Old Nov 20, 2005 | 02:51 PM
  #18 (permalink)
SpottedMango's Avatar
Driven Concepts, Tampa FL
Do a leakdown test, before spending somemore money on a motor that you might not need.
Driven Concepts, LLC
1101A East Hillsborough Ave.
Tampa, Florida 33604
813-236-4500
Monday - Friday 9am - 6pm
WE ARE DIRECT
Tein, GReddy, Buddy Club, Bride, Tanabe, K-Sport, Power Enterprise, etc......
https://www.tamparacing.com/forums/d...ml#post4905630
Old Nov 20, 2005 | 04:10 PM
  #19 (permalink)
spoonfed's Avatar
yeah I will
Old Dec 2, 2005 | 07:48 PM
  #20 (permalink)
willhunting's Avatar
How do u like them apples
If the head gasket is cracked would there be coolent leaking out?
My boy is wicked smart
-Morgan
It's a nissan thing.
