ball joint problems...
Old Nov 16, 2005 | 01:05 PM
Zapatista's Avatar
'89 Rattle Can Special
Default ball joint problems...
Im having problems detaching the ball joint from the brake assembly. Ive slide two ball joint forks in at the same time and still cant get it to pop loose any ideas guys?
Old Nov 16, 2005 | 01:10 PM
Epstein's Avatar
Retired
put the nut on the threaded part of the ball joint upside down so that it makes a flat surface (ie, nut flush with top of threaded portion). Hit with large hammer. Repeat.
Pickle forks suck. I just hammer everything now.
Old Nov 16, 2005 | 01:23 PM
Zapatista's Avatar
thanks for the tip! should I leave it installed on the car or take it off and do it on a bench?
Old Nov 16, 2005 | 03:27 PM
Epstein's Avatar
Retired
I prefer doing it while it's still attached to the strut, on the car. Its easiest that way. Knock out the tierod and just spin it around.
Old Nov 16, 2005 | 03:48 PM
osama tim laden's Avatar
kings cannot fall.
just asking, but you arent taking that off to replace the t/c rod you messed up are you?
Old Nov 16, 2005 | 04:21 PM
I'm Phucked's Avatar
army pilot
easiest way is 5 or 10lb sledge to the solid iron housing (aka spindle) that the stud of joint goes through and gravity does rest 99% of time.
In a relationship you are either man or woman choose wisely [fortune cookie @ Ling's garden]
Originally Posted by Tackleberry
thats an insult to a circus
Old Nov 16, 2005 | 04:31 PM
kings cannot fall.
or use a ball joint seperater. (not a pickle fork, since they just ruin it anyway.)
Old Nov 16, 2005 | 05:36 PM
Epstein's Avatar
Retired
or just hit it directly! jeez people.
Old Nov 16, 2005 | 05:53 PM
kings cannot fall.
sometimes hitting it directly can mushroom the end and stretch the bolts, even with the nut on it. depending on how stuck it is though.
Old Nov 16, 2005 | 08:51 PM
In_DET's Avatar
cheap balljoint press works well too.
