What is this part?
So I hit a curb the other night. I snapped a tie rod and this part. I dont know what its called or where to get one any help would be appreciated. I fixed the tie rod so thats good. It is a 89 240 coupe. The part is on the drivers side front.
Thanks Zapatista. http://i29.photobucket.com/albums/c2...brokenpart.jpg |
tension rod get a tein one there nice
any removal tips?
loosen bolts remove part, replace part, tighten bolts?
17mm and a breaker bar! You'll need a 17mm closed end, too, to hold the tension rod bolt.
thank you sir!
You can also buy the ones from PDM racing. Thats what i got for mine and they are really good! They sell just the bushings too. They are easy to remove if you can borrow a press. Its cheaper too.
Here is the link |
