Tranny Swap 300z/SR20
I am swapping to a 300zx tranny instead of using a KA tranny every 6 months. Anyone here have this done? Have any input for me about it?
I am also switching to a MAP tuned rom-tuned ecu.
stinkyz replaced the s13 trans he was using in his 87z with a z32 trans. something about input shafts, 5th gear and a bellhousing. email him or something. had to use parts from both trans to get it to work.
SHIFT_old school
399.5 hp 430 tq on 95k mile junkyard motor
12.0 @ 118.22 1.89 60`
DILLIGAF?
SHIFT_old school
DILLIGAF?
Originally Posted by Epstein
what's all this about MAP and ROM tunes?
as for the tranny swap I have everything accept a custom drive shaft. i am wondering if i can customize my alluminum drive shaft or my 180sx drive shaft. Or do I use 300z? I also am worried about where the shifter will end up. I have read that it gets moved about an inch back with the swap. I sure would like to see one that is already done....
Guest
Posts: n/a
[QU073=D|21f71|\|gDJ]d01|\|g 4\^/4y \^/17h 7h3 m4f g0|\||\|4 5h007 f0|2 500hp \^/17h 4 u5b l04d3d |20m-7u|\|3 0|\| M4P 53|\|50|2 \^/17h 2 fu3l m4p5. 1 \^/1ll k33p 4 l4p70p h00k3d 70 7h3 3cu ju57 f0|2 g4ug35.
45 f0|2 7h3 7|24|\||\|y 5\^/4p 1 h4v3 3v3|2y7h1|\|g 4cc3p7 4 cu570m d|21v3 5h4f7. 1 4m \^/0|\|d3|21|\|g 1f 1 c4|\| cu570m1z3 my 4llum1|\|um d|21v3 5h4f7 0|2 my 1805>< d|21v3 5h4f7. 0|2 d0 1 u53 300z? 1 4l50 4m \^/0|2|213d 4b0u7 \^/h3|23 7h3 5h1f73|2 \^/1ll 3|\|d up. 1 h4v3 |234d 7h47 17 g375 m0v3d 4b0u7 4|\| 1|\|ch b4ck \^/17h 7h3 5\^/4p. 1 5u|23 \^/0uld l1k3 70 533 0|\|3 7h47 15 4l|234dy d0|\|3....[/QU073]
|234d 7h3 l1|\|k 1 p0573d. 17 h45 3v3|2y 4|\|5\^/3|2 70 y0u|2 qu35710|\|.
tim... i still have those lines i have to drop by xat this weekend
Jonas
Jonas
A buddy of mine has a 300zx transmission in his '91 Coupe right now.Mark fabricated a bell-housing, brackets and tranny mounts to use on the chassis. Basically you use the yolk from the Z32 Driveshaft and the Back of the S13 Driveshaft bolted up to the LSD. Mark also makes the custom 1 piece driveshaft for the Z32 Tranny to be used with a 240.
The shifter sits about a little under 2 inches further back and maybe an inch to the left. The location is homely.
