Rear Main Seal ?
Old Oct 29, 2005 | 08:22 AM
Projekt's Avatar
No
Default Rear Main Seal ?
ok my rear main seal has started to leak. in order for me to fix it i have to remove the tranny. heres the dillemma i recently had a problem with my torque converter and it is now welded into place and has lactide around it to insure it doesnt coem loose again.if have to fix the rear main seal the converter bolts will have to be cut and that means more work. heres my options
1 i get a new converter
2 i do a 5-speed swap
please help me out i need to do sumthin soon because right now ill have to purchase oil once a week
Old Oct 29, 2005 | 08:57 AM
Projekt's Avatar
No
Originally Posted by Mars_302
cheapest is replace converter and easiest. You will also need a new flex plate by the sounds of it
And why did you weld the converter?
the converter came loose and we replaced the bolts with brand new ones
after about a week it came loose again...the only way for it to stay on was to weld them in place
also the converter would be around $300-400 and the swap would be $300-500
