Front A-Arm Bent?
So, this has been said 50 trillion times before in this forum. Drifting and curbs dont mix.
This being said you probably know whats coming next. I just need to verify and then fix.
I hit a curb with the passenger side front wheel on the 91 s13. This created a nice little angle. It is turning left while the driverside front wheel is str8. I put it up and looked to see if I could see a bend, but do not know what I would be looking for. During steer to fulllock, there are smooth with little resistence spots, and normal feeling resistence.
I thought maybe tie rod, then possibly a-arm, my question to youse guys is how would I differentiate the two in diagnosing this problem.
As always Appreciated Info.
Reguards
Pho
This being said you probably know whats coming next. I just need to verify and then fix.I hit a curb with the passenger side front wheel on the 91 s13. This created a nice little angle. It is turning left while the driverside front wheel is str8. I put it up and looked to see if I could see a bend, but do not know what I would be looking for. During steer to fulllock, there are smooth with little resistence spots, and normal feeling resistence.
Reguards
Pho
Buying/Selling on TR is like shaving your ass before going to prison. You know your gonna get fucked, you just try and make it as pleasant as possible.
Your tierod is bent , if one wheel is turning left and the other is straight. Do not drive the car , it is dangerous to drive like this. Your control arm maybe bent as well, but your tierod is definetely bent.
Appreciated, the car wont move again till its fixed. Hopefully tonight.
