Dyno SNAFU!!!
260@15psi? yeah I'd say thats a lil low. You should see proper numbers when the maf/map thing is taken care of.
01 Sentra 1.8 turbo (sold)
91 Sentra SE-R turbo (sold)
03 350z turbo (RIP)
07 Mazdaspeed3
03 350z turbo (RIP)
07 Mazdaspeed3
What trim is your turbo because I don't see those numbers as being low for CA18. With a GT28RS .86 on my SR20, Z32 MAFS and 740cc injectors I got 315 at 18psi with an Enthalpy dyno tune. Thats .2 liters more displacement and 3psi more boost. If you go by the semi-faulty "1psi=10hp" statement, if you ran 18psi you'd be up at 290hp with that turbo, which is pretty good for a CA assuming you're using the .86 and not the .64
I wasn't planning on much over 300hp, I would be content with that.....howver i'm not extremely happy with the results, I am impatient for the MAP sensor swap. I always have a Q45 MAF on backup if I can't wait.
< < < < < PANDA FINGA!! > > > > >
Individual pins need to be run form the ecu to the MAP. The tech at AEM was on vacation, so we're waiting for him to come back. CA's didn't come with MAP, so it needs to be wired directly.
Lyon: Yeah. You and me both, brother.
