omfg, automatic pilot bushing removal?
automatic KA24DE
how the FUCK do you get that thing out of there? i have been going at it now for hours with a chizzle and a hammer and pliers and this fucker wont come out and im getting REALLY pissed.
anyone have a simple solution?
http://www.floridaracing.org
Guest
Posts: n/a
If its not too chewed up you can rent a puller from Advance Auto Parts that will get it out in 2 minutes (found this out on Frankenstang). I've had good luck with a hammer and chisel, but the chisel DOES need to be sharp. Hell, we did Hoonta's clutch a few weeks ago and it too 2 minutes.
What does the automatic use a pilot bushing for?
the manual ones are easy, this automatic one is a cunt job.
my manual one sucked too. it was like work heated in.
try getting a small long drill bit, and drilling out the top and bottom so they seperate it into two "C" (one mirror to the C) and then try chiseling. that worked for me,
I strongly suggest getting the right tools for the job. Like he said above, you can rent a slide hammer bearing puller from any auto parts store, and get it out with a couple good slides. Sure beats the hell out of messing up your crankshaft, and having to sand it for your new bushing to go in.
i went and got one of the tools from discount, fuckin snapped the bitch
$20 if anyone can come get this fucker out tomorrow (prefer morning)
if pulling as hard as i can with pliers doesnt work, i dont know what toilet paper will do.
