My sr20det has a miss!
Old Aug 23, 2005 | 03:14 AM
roachhatch's Avatar
lick my balls, buddy!
Default My sr20det has a miss!
Alright nissan experts,
I have a blacktop sr20det that I've had in my car for around 2 months, and the car has had a miss the whole time - First everybody told to switch the plugs, which I did, and the miss just got much worse! Then, I was told to just have a new wiring harness made, which I did - Durden perfab. Now the only things left would be coilpacks and injectors. When the a/c comp turns on, the motor runs fine w/ no miss. U turn it off, and the miss comes back! Is there anyways to test coilpacks? I mean, obviously switch them out one @ a time - but I don't have spare coilpacks laying around. I think if it were an injector it would miss all the time, right? Anyways - any help out there, or anybody wanna help me out - would be great, thanks
matt
Darkness!
Old Aug 23, 2005 | 04:33 AM
Epstein's Avatar
Retired
Could be anything, but the change with the plugs is a clue. What are they gapped to?
How does the car run otherwise?
Old Aug 23, 2005 | 05:27 AM
vertigo_16201's Avatar
are you running too rich or too lean?
Old Aug 23, 2005 | 05:51 AM
roachhatch's Avatar
Well..... I dont have an air/fuel guage, other than that miss the car seems to pull hard, and with out any serious bogging.
Darkness!
Old Aug 23, 2005 | 06:01 AM
Epstein's Avatar
Retired
now that sounds like a leaky injector or small vacuum leak.
Old Aug 23, 2005 | 08:09 AM
yah a vacuum leak could cause enuf unmetered air to cause a lean condition at lower airflow rates i.e. idle
Old Aug 23, 2005 | 08:41 AM
roachhatch's Avatar
That would be the reason it goes nuts when I start it up, It barely runs, jumping around in the rpms til the car warms up - then its okay. The guy who did the swap said its because ive got an open air bov, but the bov was brand new and its closed during no boost.....so i dont see that causing anything....any other places i could have a vacuum leak? - blake....if you can fix my car ill throw ya fifty, what ya say?
Darkness!
Old Aug 23, 2005 | 09:06 AM
i dont really have time this week bro. Try taking some girl you like to the store, buy some magnum codoms and put 1 over the bov and see if it runs betetr (out of boost of coarse)
Old Aug 23, 2005 | 05:13 PM
asia989's Avatar
Why So Serious?
change the fuel filter out
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Aug 23, 2005 | 05:20 PM
Epstein's Avatar
Retired
wtf fuel filter? The fuel pressure is already down to about 32psi at idle. If you had a fuel flow restriction under those conditions, you wouldn't be able to make it through the parking lot without detonating.
*edit* wrong fuel pressure. Can't subtract inmg from psi!
