speedo went out
Old Aug 20, 2005 | 09:59 PM
Superkaioken's Avatar
Default speedo went out
my speedo went out do i need to crack my entire dash boared open to fix it. when i hit the dash bored it comes back on but it will go out and come on over and over.
Old Aug 20, 2005 | 10:45 PM
craig_302's Avatar
boostmonkey
searchsearchsearchsearchsearchsearchsearchsearchse archsearchsearchsearchsearchsearchsearchsearchsear chsearchsearchsearchsearch
Old Aug 20, 2005 | 10:51 PM
OniS14's Avatar
do it BIG!!
get a new gauge..or check wiring..
possibly sell the car..buy sumthin new..no problems there
S14 parts f/s
STANZZZZZZZZZZZZZZAAAAAAAAAAAHHH
Old Aug 21, 2005 | 03:03 AM
Epstein's Avatar
Retired
Sounds like you're on the right track with the dash board whacking. To get the cluster out, you're going to have to remove the knee panel, lower the steering column (only 4 bolts), and pop out the cluster trim. Since you know that the problem is in the dash, it's probably a loose connection on the cluster itself. Use rubbing alcohol to clean up the contact on the cluster.
Tell us how it comes out. A lot of people are having cluster problems all of the sudden.
Old Aug 22, 2005 | 02:11 PM
Anthony R's Avatar
SAL-T
same problem. it is a short under the dash to the gauge cluster.
Old Aug 27, 2005 | 06:05 PM
JDMjunkie's Avatar
maybe it's your wiring thats what i'd check first
TampaRacing's DEAD!!
Old Aug 27, 2005 | 06:27 PM
jk240sx's Avatar
coast to coast
Sounds like bad connection...get some contact cleaner, and some steel wool or fine sandpaper and clean all the connections.
jerry/
Old Aug 27, 2005 | 08:22 PM
tak's Avatar
tak
A to the K
what he said up there. Taking your guages out isnt hard at all. 5 min job with minimum tools (12 or 14mm socket for the steering column, and a screw driver pretty much for the rest) have fun not braking the trim tho ;]
Old Aug 27, 2005 | 11:24 PM
RubberBerner's Avatar
Sideways Maffia
yea, if you don't wanna crack your dash, you better drop the steering column because otherwise its a bitch to get out without cracking it and scratching it all up.
NOBAMA!
