Torquing advice
Old Aug 18, 2005 | 12:41 PM
S13NewB's Avatar
Vice President
Default Torquing advice
ok i was almost done installing a new thermostat today and water pump and i was torquing the bolts for the top radiator inlet pipe that hold in the thermostat. So im doing it all by the book, and i was only gona torque it to 14ft-lbs when the manual says anywhere from 13 to 16ft-lbs would be fine. one of the corners of the inlet pipe cracks off. im like wtf? so before i go digging for through junkyards another one, is this gona happen again? is 14ft-lbs too much?
one more thing. the FSM that i used was for an SR, but i figured that the coolant systems couldnt differ that much. was that a stupid thing to do?
oh and i was torquing all 3 corners gradually. not one at a time.
Old Aug 18, 2005 | 02:19 PM
Epstein's Avatar
Retired
That is a freak failure. 14ft-lbs isn't enough to break anything. Just make sure to inspect the new one you get. I have a feeling that the original one might have had a crack to begin with.
By the way, there's no reason why people should not have the right FSM for their S chassis. www.zeroyon.com has all of the USDM FSMs for every 240sx. Everything except S13 with SR in english (which does not exist) is available for free download.
Old Aug 18, 2005 | 02:22 PM
osama tim laden's Avatar
kings cannot fall.
general rule- on anything other than headbolts, or internal engine parts "tight" is good enough. no need to break out a torque wrench.
nothing wrong with being anal about it though at all.
Old Aug 18, 2005 | 02:41 PM
S13NewB's Avatar
Vice President
thanx. very informative
Old Aug 18, 2005 | 11:39 PM
RubberBerner's Avatar
Sideways Maffia
Depending on if you have good judgement of "how tight". I had a fucking tard break off 2 bolts in the head, trying to reinstall the rocker arm rail in a Neon. Then some other bolt i can't remember. long story short-he got the wrong sized helicoils, and i fired him, and had to do 2mm's bigger with timeserts, so that freaking rockerarm rail ain't goin nowhere!
NOBAMA!
Old Aug 19, 2005 | 03:52 AM
kings cannot fall.
well, common sense is pretty much needed.
Old Aug 19, 2005 | 06:39 AM
DriftingDJ's Avatar
240LSX
I did the same thing to mine my thermostat is held by 2 bolts I am one of those people that needs more common sense when it comes to tightening shit I go overboard maybe its because my motor rattles lose the tightest bolts even with lock tight.
Old Aug 19, 2005 | 09:34 PM
Sideways Maffia
go by the OEM torque specifications, and if it breaks...you know it wasn't as strong as it should've been!
NOBAMA!
