KA24DE swap. Help!!
<commercial> did you try to work on your car yourself? did you buy an unfinished project? were those instructions on the internet not as complete as you thought? are you in over your head? Call 1800 AX DURDEN! He'll have your car rollin under it's own power again! </commercial>
Seriously, this is a deal to just be done with it.
Question: Would the temperature sensor prevent the car from starting? The engine is turning and all of the accessories are working but i don`t think that the temperature sensor has been replaced.
I`m not sure if the previous owner knew what he was doing. He actually gave up on the project. I did noticed that the coolant lines on the intake manifold were different from the S13 but didn`t think that they would be an issue.
* Hey Taylor thanks for posting. Let me see if i can figure this out and i`ll let you know. Are you a mechanic for a shop? Which one is your car? I`ll come up to you at a carmeet if i see you.
Juan - you have a slight typo in your sig. Taylor used to work for XAT. I'm surprised you can't figure out the problem. I think you should see about paying Taylor to stop by your shop for a little while and help diagnose it. Between you two guys you should be able to figure it out. Oh yeah I finished the Flash intro - let me know when your ready to upload it.
Thanks for catching the typo bro. I did this swap before on my black coupe but i think that the previous owner messed around with the harness and i`m lost. I think i`m close thou.
Hey i`ll let you know about the flash intro. I had to delete yahoo messenger because it was giving me too many pop up windows. Is there a way you can send it to me?
I will try to email it to you. Hopefully you can figure out how to get it loaded onto the main web page. You will have to make a button below it to go to the main website though.
