Z32: How to use Ford motor mounts for a cheap stock replacement.
Old Jul 8, 2005 | 07:48 AM
Rob.M's Avatar
Down Shift Magazine
Default Z32: How to use Ford motor mounts for a cheap stock replacement.
Since, there is a definitive lack of Z32 tech in this forum, I thought I would post up one of the newer faqs posted on TTNet for the Z32. Credit to both ZLuster and Florida's own Ash Powers for this one.
This willl guide you through how to replace your old stock motor mounts with ford truck motor mounts which are cheaper and readily availible. The part number for them is 2698, made by Anchor, they cost about $30 at autozone and are usually in stock. They come out of a 1989 Ford F150 inline 6 cylinder 5.9Litre. The motor mounts themselves overall sit about 5-10mm higher, the threads are longer(doesnt effect anything) and the threads are larger by about 2mm.
To replace both you will need:
2 New Motor mounts
4 New Nuts(7/16 regular thread)
2 Washers(for the lower side on the subframe)
2 Files, one round, one flat.
Here you can see the differences between the two mounts:
Step one:
Remove motor:
Step two:
Using the flat file and open up the holes on the subframe enough for the motor mount to slip in.
Step Three:
Use the round file to open up the hole on the motor mount bracket on the engine.
Step Four:
Reinstall engine
Old Jul 8, 2005 | 08:45 AM
HaloZ's Avatar
highway whore
Originally Posted by John
steps one and four are in EVERY Z32 how to
but cool info none the less
*Z32TT*
NAs are easy to work on.
Old Jul 8, 2005 | 09:23 AM
craig_302's Avatar
boostmonkey
Beefy.
Old Jul 8, 2005 | 09:52 AM
HaloZ's Avatar
highway whore
90 ish each. http://www.courtesyparts.com/Merchan...e=Z32-MTR-MNTS
Old Jul 8, 2005 | 01:01 PM
Rob.M's Avatar
Down Shift Magazine
Originally Posted by HaloZ
Yes, I should have clarified that it was for a TT and as everyone can see the OEM mounts are indeed very jacked up in price. Coz Ceh gets them slightly cheaper but not at too much of a discount beyond that. BTW, if anyone is looking for OEM Z32 parts I highly recommend Coz as the man to talk to. http://www.conceptzperformance.com/ certainly one of the pillars of our community. Even the highway whore HaloZ has used him.
