overheating problems
Old Jun 12, 2005 | 04:20 PM
forceFEDs13's Avatar
SUPAFLY!!!
Default overheating problems
well......after i found that my water pump gasket was leaking....i fixed that and now for like the first 5 min of running the car is fine....and then it goes up to the last dash before the H for like a minute and then it goes back down to normal opp. temp and it dont go back up till i turn the car off and then turn it back on....has this happend to ne one before? Any tips help.....thanks
Miles
BANZAI
ADHD= Always Drifting Hardly Driving
Old Jun 12, 2005 | 04:52 PM
steve's Avatar
madpom
bleed the system
Old Jun 12, 2005 | 05:28 PM
Projex240's Avatar
got air trapped in the system.
what ^ said
Old Jun 12, 2005 | 06:29 PM
SUPAFLY!!!
how u do that?.....the head snapped off the bolt on the intake manifold if thats what your talking about....
BANZAI
Old Jun 12, 2005 | 07:40 PM
steve's Avatar
madpom
well you took the water pump of air got in
you have air traped in there
Old Jun 13, 2005 | 05:20 AM
gritt's Avatar
Fuckelberry Hound
i don
SHIFT_old school
399.5 hp 430 tq on 95k mile junkyard motor
12.0 @ 118.22 1.89 60`
DILLIGAF?
Old Jun 13, 2005 | 05:25 AM
gritt's Avatar
Fuckelberry Hound
i don`t recall how a ka or sr or whatever you have is set up, but this may help you. i take it that bolt you snapped off is for the air bleed for the cooling system? if this is the case then the rad cap is lower then the bleed screw (i`ll assume) we had this issue on M-B 300E when we did evaps air would get in the system, be a bitch to bleed and you could hear it bubbling inside the system from the drivers seat. we had to raise just the front of the car on the lift, high enough so the rad cap was the highest point of the cooling system and let it run for a bit like that, to let the trapped air out. just a thought. i like i said i don`t remember how those engines/cooling systems are set up.
SHIFT_old school
DILLIGAF?
Old Jun 13, 2005 | 10:09 PM
ImportLuv's Avatar
Usually if the gauge goes up and down its caused by air pockets in the system. I let mine idle for awhile with the radiator cap open and keep filling it up. Drive it around a few times, fill it up again, if needed, keep doing it until no more jumping from the gauge. I had that problem when flushing out my radiator.
