z32 brake conversion
Old May 28, 2005 | 07:47 PM
S13NewB's Avatar
Vice President
Default z32 brake conversion
i've almost got everything i need for my s13 to z32 brake conversion but i still need lines. now will any steel z32 lines work? or do they have to be special conversion lines for my s13. thanx.
Old May 28, 2005 | 08:01 PM
S13NewB's Avatar
Vice President
oh and should i forget any idea of wanting to keep the e-brake if i convert the rear brakes too?
Old May 28, 2005 | 08:18 PM
Jeff240sx's Avatar
Cpt. Negative
Yes (special conversion lines or apparently Silvia lines), and yes.
-Jeff
** This space reserved for someone else's witty quote **
Old May 29, 2005 | 04:15 AM
RoadRacer's Avatar
Turn 7 at Sebring
Yes you need a line that will fit the s13 hard line and the z32 caliper (they have two different type of connectors). I got mine from in Enjuku. Contact Matt via AIM @ Enjuku Matt
I think Taylor might be able to get the lines. Taylor Durden on TR. You have to fabricate a bracket if you want to keep the e brake. Contact Durden perfabbbbbbbbbbbbbbbbb.
Patrick -
Old May 29, 2005 | 04:17 AM
osama tim laden's Avatar
kings cannot fall.
http://www.projectnissan.com/shoppin...idproduct=2098
Old May 29, 2005 | 06:36 AM
Durdan's Avatar
No Ants Drift Member
you can keep the ebrake if you get either J30 or G35 ebrake cables, then a bracket just needs to be made, but its not too bad
as for the lines, i would just have amazon make some as john said
RIP Tim. i miss you, buddy
Old May 29, 2005 | 07:06 PM
S13NewB's Avatar
Vice President
so should i go to an infiniti dealer to order the e-brake cable? i cant find it on the internet.
