sr20det 2800 rpm noise
Old Apr 29, 2005 | 05:51 PM
Animosity's Avatar
Default sr20det 2800 rpm noise
i got a ticking noise only at 2800 rpms and goes away at higher rpms any ideas?
btw its a redtop s13 sr20det, ive got a fmic, stage 3 clutch bov dunno if this helps any
Originally Posted by dr. octogon
"hey, jeeves, where can i get an fwd sr20det"
jeeves: anywhere asshole !
Old Apr 29, 2005 | 05:53 PM
Evangelion's Avatar
Where in the engine is it coming from, head or the block?
Old Apr 29, 2005 | 05:56 PM
Animosity's Avatar
im not to sure, i just hear it, cause i dont have someone to rev the engine while i listen, i just hear it tick at 2800 rpms
Old Apr 29, 2005 | 05:57 PM
Animosity's Avatar
i was wondering if this happend to anybody else maybe they could tell me what it is, it doesnt sound like a rod knocking
Old Apr 29, 2005 | 07:53 PM
cubanprince1's Avatar
shift.............vroooom
Damn, its happening to me. I thought it was the transmission. I was hoping it was the transmission. From what ive read, these noises at 3k rpm mean the beginning of a rod knock. Ive had this since i got the car back though and it hasnt got any worse (thank god). I have ran 19 psi a few times and still same. Car made good power also. I would guess if it was a rod knock or bearing then it would have gotten bad by now? It happens around those rpms and i can get it to do it manually by pressing the gas pedal softly or letting go of the gas pedal softly. It sounds almost like a vibration. Like something hitting against something else very fast. I dont know how to explain it. Martin from xat first thought it was a bearing but after a few 19 psi runs he began to think it is my tranny/clutch since my tranny is messed up.....Hope its nothing bad.....Lemme know if you figure it out man.
Norlandt
http://inductionperformance.com/
Induction Performance - 727.505.1423
AEM EMS Tuning, Builds, Assembly, Custom Kits, Installs and more.....
Old May 1, 2005 | 09:13 AM
Lurch's Avatar
you only live once...
I think it's a bad wrist pin on one of the pistons, or something like that i've heard that noise before it could happen from anything, basiclly if your worried youll need to get head bolts head gasket and a rod and piston thats if thats the problem.
Old May 1, 2005 | 11:48 AM
Animosity's Avatar
k thank you
Old May 1, 2005 | 02:58 PM
What does it sound like and does it do it while its idling and u rev it to 3k rpms?
Norlandt
Old May 1, 2005 | 03:48 PM
DriftingDJ's Avatar
240LSX
excessive vibration in the shifter?
Old May 1, 2005 | 03:55 PM
DriftingDJ's Avatar
240LSX
if so thats when the downpipe is vibrating your driveshaft and tranny secure it down and out of the way better. one of the little tweaks of having a rhd sylvia motor in your lhd 240sx.
