Front LCA issues..
Earlier today I started replacing both my front LCAs and ran into a few problems. The driver side was easy as cake, the passenger on the other hand is just being a bitch. My biggest problem is that the bolt that attaches the arm to the body is rusted inside the metal sleeve in the bushing. No biggie I thought at first, I'll just find another one and cut that one off, no go...nowhere has the right size bolt, anyone have any suggestions on that? Next I was just going to put everything back together and finish later, can't do that either. I started to put the nuts on the tie rod & ball joint on the LCA but they only get so tight then the whole joint starts spinning. Now I have to buy some new tie rods, which I'm hoping aren't too tedious to replace.
So to summarize, what size is the bolt that goes through the LCA bushing? Or a good way to get one rusted to the bushing out? And, are tie rods difficult to replace? Thanks.
AIM gwhIIx
AIM gwhIIx
Are tie rods difficult to replace?
Yes in Lexington Oaks. The tie rods are not my biggest worry, I was just asking so I'd know. I will figure them out, I just want to find a way to get that friggin' bolt out of the control arm, or find somewhere to buy the right sized one so I can cut it out. I might just try putting some more weight into it to get the old stuff back together. Thanks for the responses though.
AIM gwhIIx
AIM gwhIIx
craig_302
Sep 23, 2002 02:52 AM
