If it's not one thing...it's another.
Old Apr 4, 2005 | 09:17 AM
_Charles_'s Avatar
formerly 'RiceRocket'
Default If it's not one thing...it's another.
So i replaced the gaskets on the manifold and turbo. Now I have an oil leak. I think it's coming from the oil line from the block....but not sure (yes, I used new copper washers). I also moved the dip stick tube around while removing the manifold/turbo. Any chance it might be coming from the dip stick tube? I obviously can not see where the tube attaches to the motor.
Charles
BTW: Replacing P/S lines fixed my P/S leak....'bout time.
My Blog: www.HotRodCaddy.com
Old Apr 4, 2005 | 09:58 AM
Matt Vassallo's Avatar
lifelong learner
Make sure the oil supply line banjo bolt is tight, and not cross threaded.
many people cross thread that bolt while attempting to get the banjo threads started into the aluminum block.
rest in peace tim.
Old Apr 4, 2005 | 10:11 AM
_Charles_'s Avatar
and if it is cross threaded? becuase I know it's tight.
Old Apr 4, 2005 | 11:35 AM
Chin's Avatar
MASTER BREWER:HOT TEA
then you moved the threads on it...Might have to retap it if its bad, but I think you would feel it if it was cross threaded.
Old Apr 4, 2005 | 05:41 PM
_Charles_'s Avatar
well....it wasn't crossthreaded. I pull the bolt out, checked it closely, and stuck some new m10 crush washers on it....and what do you know....she doesn't leak oil anymore. I think I left about a quart of oil on the howard franklin this evening on the way home for work...
Charles
Old Apr 5, 2005 | 11:58 AM
Ronald Mcdonald's Avatar
Shakotan/Hippari life.
good job man....i like ur car alot.
-'03 GSX-R 750
Scott
Aug 9, 2003 12:09 PM
jaball77
Jul 9, 2003 05:26 PM
BIG_Truck_Driver
33
Aug 30, 2002 05:53 PM
