Where do you buy your engine rebuild kits?
Old Mar 30, 2005 | 12:16 PM
ZenkiS14_Drifter's Avatar
Wombat S14
try this Tyler http://boostdesigns.com/store/index.php?cPath=41
-Bryan-
Old Mar 30, 2005 | 12:42 PM
MaxType 240's Avatar
All Around Maxed
Originally Posted by ZenkiS14_Drifter
Negative.
A. He's not doing a performance build
B. Cometic is $20 overpriced (if it's for an HP)
C. TOGA Bearings are overpriced by almost $100
Tyler, here are the part numbers & such for the timing components (total is $243 plus S/H):
13070-ad503 Timing Chain Tensioner-Lower for 2.4-liter DOHC (KA24DE) engine 49.9
13070-4e101/102 Timing Chain Tensioner - Upper 49.9
Tension Side Bolt (1) for Timing Chain Guide for 2.4-liter DOHC (KA24DE) engine
13091-53f01 Timing Chain Guide - Slack Side for 2.4-liter DOHC (KA24DE) engine 64.41
13085-1e401 Timing Chain Guide - Tension Side for 2.4-liter DOHC (KA24DE) engine 11.72
13028-5b600 Timing Chain-Lower for 2.4-liter DOHC (KA24DE) engine 39.9
13028-53f11 Timing Chain-Upper for 2.4-liter DOHC (KA24DE) engine 27.66
Ings RSpec, Built KA24DET, GT3071R
VR-4 AWD/TT Winter Sled
Old Mar 30, 2005 | 12:50 PM
TNathe's Avatar
Thanks fellas. Im not going as far as a aftermarket rods, arp studs, or headgasket Bryan. Just forged pistons. Im shooting for 350hp so all the other stuff will be overkill for now. I also sort of like the fact of having the headgasket as the "weak" link in the engine incase something decides to not cooperate its just a $50 headgasket and a day or two of labor and not a complete rebuild.
Old Mar 31, 2005 | 08:43 AM
Wombat S14
good call, works for me mang. just throwing options out. And now that i know its overpriced that helps to.
-Bryan-
Old Mar 31, 2005 | 06:54 PM
Enthalpy's Avatar
TR Balla Donor Supreme
tyler,
if you have it apart...why not do headstuds and a headgasket?? its onlya bit mroe money...and you already have it apart now. do it right...do it once.
Old Mar 31, 2005 | 07:50 PM
dan's Avatar
dan
Get the fuck off my lawn
stock headgasket $50...or cometic for $65????
plus, you needn't worry about having "weak spots" if you get it tuned right.
Old Apr 1, 2005 | 04:28 AM
  #17 (permalink)
TNathe's Avatar
isnt the $65 cometic pretty much an aftermarket stock replacement, not really any better than the $45 discount auto ones? I was also advised that I do NOT need to replace the studs, but if it is a good idea and there is some justification for it other than "you'll be able to more power down with them if you decide in the future" then I suppose I would.
Old Apr 1, 2005 | 04:54 AM
  #18 (permalink)
All Around Maxed
Cometic MLS can be had for $69 plus S/H. MLS are known to withstand power. So much so, that Cometic may discontinue the HP series and just stick w/ the MLS.
Jesse
Old Apr 1, 2005 | 05:11 AM
  #19 (permalink)
TNathe's Avatar
RAD! Well since I have to buy a new headgasket anywho might as well spend another 20 bucks and get something that'll hold out eh? Talk to EngineLab Jesse about Sat. morning?
PS: Thanks for all the replies guys!
Old Apr 1, 2005 | 05:15 AM
  #20 (permalink)
VoidDweller's Avatar
I'm in the same boat as Tyler. However, I'm still VERY new to Nissan, but I was under the impression that you should always replace the OEM studs when you do a rebuild because they stretch. ARP are comparatively expensive, but seem like a good option since they can be reused if necessary.
Enthalpy:
You have a good point on the gasket and studs, but what is your opinion of the 'safety factor' afforded by having an OEM head gasket? For the KA experienced, the OEM is probably a waste of time. But for the inexperienced, Tyler may have a point as it may save the engine if something was overlooked.
Epstein:
I've been using Courtesy for my B14 and the prices were about 20% less than local dealers and had a very good experience with their customer service. I haven't priced S13 parts yet...
MaxType 240:
I'll give Pinnacle a call and compare prices with Courtesy over the phone to see who has the best shipped prices on OEM parts. I've also heard good things about IPP, so it nice to see another positive comment on their business.
_____________
_______
04 TSX
97 240SX SE (SR20DET)
PM if you need B14, S13, KA or SR parts
http://www.engrish.com/
