Dyno Tuned Boost Designs Stage II Kit
Old Mar 23, 2005 | 11:49 AM
coolcloo1019's Avatar
Uhhh...
I sense some hostility coming up in this thread. maybe thats just me
other than that it looks pretty good to me.
Tennessee Vols
Old Mar 23, 2005 | 12:43 PM
xatracing's Avatar
Originally Posted by Ostrich
COMMON?
Maybe you need to take more off of the flywheel surface, as well as get the step correctly on the flywheel, so you get OE specs. There should be no difference between a re surfaced flywheel and a brand new flywheel in terms of how a brand new clutch grabs.
This is how one of our resurfaced flywheels look. It is cross cut on a circular stone lathe. You see the circular pattern radiating... These are raised ridges from the process which the clutch disk will wear even after a proper break in. Until then you have a "spoongy" sufrace which does not have as much surface area as a broken in flywheel with a flat surface. This type of resurface gives you about the best break in when it breaks in. Until then, like I said, less surface area will promote slip under good power.
martin
Old Mar 23, 2005 | 12:45 PM
xatracing's Avatar
Old Mar 23, 2005 | 02:36 PM
180SX's Avatar
BTW.. this is the same kit on 8 psi.. sae corrected / smothing 3 .. just because i caught some flak for that .. and the same 12 psi run as up top .. but sae corrected... btw that is 288 foot-lbs torque at 3700 rpm... no clutch slip down there.. the reason for the down low bump is that the set boost was acting up....KA's are cool
martin
XAT Racing
813-875-7223
www.xatracing.com
Old Mar 23, 2005 | 02:40 PM
180SX's Avatar
Old Mar 24, 2005 | 03:42 AM
Durdan's Avatar
No Ants Drift Member
i only said to set the correction and smoothing in order to make his graph on the same scale as everyone else pretty much uses. that way we would get a better idea and make sure theres no graph discrepences
RIP Tim. i miss you, buddy
Old Mar 24, 2005 | 04:29 AM
  #17 (permalink)
Matt Vassallo's Avatar
lifelong learner
martin
Maybe you need to resurface your flywheel differnetly then. The grain is not fine enough on the surface, reminds me of a cylinder wall - how come brand new flywheels arent' like that then, if that's the best way to do it?
rest in peace tim.
Old Mar 24, 2005 | 07:11 AM
  #18 (permalink)
TNathe's Avatar
Old Mar 24, 2005 | 03:05 PM
  #19 (permalink)
180SX's Avatar
Good point... but here is the reason.. I have 3 grain stones to choose from when sending out a flywheel for resurface. This is the 2nd finest and it costs our customer $80... Brand new flywheels ... lets say a billet piece aftermarket.. are turned on a cc lathe... giving it a almost perfectly flat surface when it is made. I can have a flywheel turned on a number 1 stone .. but it becomes 10 passes on the lathe (3 on number 2 and 7 on number 1).. almost triples the cost.. $250 to customer. The 7 extra passes on the finest stone will give you a mirror finish and almost make it like new... Cost was an issue in this customers case. Anyways.. I'm sure you guys sell a billet ka flywheel for $350-$400.. which would make option 2 kind of pointless.. Hope that clarifies.
martin
Old Mar 24, 2005 | 03:07 PM
  #20 (permalink)
180SX's Avatar
ask and ye shall receive.. popped both 8 and 12 psi runs on correction : sae
with a 3 smoothing
martin
