f 'in motor mounts
Hey at least one of your motor mount bolts are seconds away from being stripped...10 bucks to anyone who can take out my passanger side without cutting metal...its either cut it out and use my old one or paitn around it....which im not really down for...
Yeah... When I was thinking of buying the TITAN H22 Hatch back waaaaay back in the day. I went for a ride in it. It had solid mounts. OMFG it was HORRIBLE !!!!!
Just buy new mounts. Spring for the xtra cost.
nismo mounts are chepaer than oe mounts
steve i have assloadas of stock mounts at the shop hanging out
uber cheap! you know you want to come up to the E garage again!
rest in peace tim.
rest in peace tim.
Originally Posted by aaron1017
I re-did my OEM busted motor mounts with polyurethane glue. I can be a little rough/shaky with the A/C on... but it's not that bad.
Here are some good instructions:
http://forums.vwvortex.com/zerothread?id=1188960
As for my mounts, I just removed a little of the old rubber and degreased it. Next I taped then up and squirted in PL Premium Polyurethane Glue. I let them sit in the oven for almost 2 days on 200*F and put them back in.
With no A/C, idle isnt bad at all. With the A/C on it gets rough.
LS1/T56 Heads Cam 1994 FD
