midpipes
Old Mar 1, 2005 | 07:13 PM
jeffronismo's Avatar
Don't be a quitter...
Default midpipes
Would regular 2+2 Z32 replacement midpipes/testpipes line up correctly on a TT converted 2+2 with the stock turbo setup? Someone told me that they wouldn't line up properly, but I just want to be sure. Thanks
Originally Posted by satanshatch
"If it's got tits or wheels you're always going to have problems with it" - My father
Old Mar 4, 2005 | 08:53 AM
BacardiRon's Avatar
Z32 Tech Bitch
No, they won't line up. You need j-spec DPs to make it a bolt on. They flow better anyway.
Tibby - Ex Sonic rusted muffler pimp
Old Mar 4, 2005 | 09:24 AM
what if you were going with a set of harry's downpipes or the greg duprees? They would line up as well right?
Old Mar 5, 2005 | 11:38 AM
BacardiRon's Avatar
Z32 Tech Bitch
The problem is most DP's were designed to replace the stock US-spec pre-cats. If you go with aftermarket DP's you need TT midpipes and your right back to where you started. The only way to make the 2+2 pipes fit is with j-spec DP's. I have a set of J-Spec's here that might be up for sale soon, but they shouldn't be to hard to track down.
Additional pointless info:
The precats only came on US-spec TT's, so the TT's got shorter midpipes to make everything fit right.
In Japan they didn't use precats so all Z's have the same midpipes.
Old Mar 6, 2005 | 08:07 AM
Right, i know that but having a 2+2 wouldn't allow me to run the TT midpipes due to length. This blows
