BEST BOV's?
my brother (cyanide) runs greddy type RS. great design, sound is between the chirpy S and the whooshy R. mid-low pitched, just sounds like rush of air not this squeaky HKS SSQV/type S bs.
my 1st gen dsm bov works fine too for $25, and you can either crush them or do the secondary port mod to run in upwards of 25psi if u want. and the sound is okay.
for function, it's either forge motorsports shim like epstein said, or the anti-stall 'configurable' BOV from ATP Turbo.
John.. Where are the inserts listed? I just wouldnt want a tweet tweet all day... I like a solid blitz chuff..
The tial was close enough and before used to be the most reliable evar...
I dont feel like a sig today.
I will need something that will be compatible with a Garrett GT pushing 18psi, and I prefer a 'whoosh' over the 'chirp'.
John, your HKS, is that the $379 one?
My Blog: www.HotRodCaddy.com
Originally Posted by Miles
i liked my time with blitz
Charles
Guest
Posts: n/a
[QU073=Ch1|\|1805><]y0u 4|23 7h3 157 p3|250|\| 1 h4v3 h34|2d 7|20ubl3 f|20m 4 714l. 4l07 0f 7h3 d0m3571c guy5 u53 7h3m 4|\|d 7h3y 571ll h4v3|\|7 h4d 7|20ubl3. 0h \^/3ll 1ll k33p 4 l00k 0u7.[/QU073]
v3|2y 0f73|\| 17 \^/0uld 571ck cl053d \^/h3|\| c0ld, 1f 73mp3|247u|235 \^/3|23 v3|2y c0ld 17 m1gh7 |\|3v3|2 0p3|\|. 175 4l50 |\|07 v3|2y g00d 47 l0\^/ b0057 0p3|24710|\| 1MH0
p5 1 h4d 7h3 11 p51 5p|21|\|g |2u|\||\|1|\|g 14p51
Guest
Posts: n/a
[QU073=|21c3|20ck37]1 \^/1ll |\|33d 50m37h1|\|g 7h47 \^/1ll b3 c0mp471bl3 \^/17h 4 G4|2|2377 G7 pu5h1|\|g 18p51, 4|\|d 1 p|23f3|2 4 '\^/h005h' 0v3|2 7h3 'ch1|2p'.
J0h|\|, y0u|2 HK5, 15 7h47 7h3 $379 0|\|3?[/QU073]
17'5 d351g|\|3d f0|2 h1gh b0057 4ppl1c4710|\|5 0v3|2 7h3 |\|0|2m4l 55QV. 7h3|23 15 |\|0 ch1|2p1|\|g, ju57 4 50l1d \^/005h 50u|\|d. H3|23'5 \^/h47 17 l00k5 l1k3
[u|2l=h77p://\^/\^/\^/.hk5u54.c0m/1m4g35_p|20duc75/1161.jpg]Cl1ck m3, hug3 p1c[/u|2l]
L157 0|\| 17 15 485
L157 0|\| 17 15 485
Guest
Posts: n/a
[QU073=5l45h]J0h|\|.. \^/h3|23 4|23 7h3 1|\|53|275 l1573d? 1 ju57 \^/0uld|\|7 \^/4|\|7 4 7\^/337 7\^/337 4ll d4y... 1 l1k3 4 50l1d bl17z chuff.. [/QU073]
[u|2l]h77p://\^/\^/\^/.hk5u54.c0m/p|20duc75/?1d=796&|25ku=[/u|2l]
0|2 4l73|2|\|471v3ly, y0u c4|\| ju57 74k3 7h3 1|\|53|27 0u7, 4|\|d 17 g1v35 4 v3|2y |\|1c3 \^/005h 50u|\|d. 1 |234lly |23c0mm3|\|d 7h47 537 up, 17 50u|\|d5 v3|2y |\|1c3
Tial is the stuff of heros. No funny sounds, just 15 lbs of compressed air leaving a 360 degree opening. Tials are picky though, you have to specify the correct spring. I used an 11 lb spring (nothing to do with the amount of boost I was running) and it worked fine. The spring it came with (7lb spring) was not even strong enough to hold it closed under vaccum.
